Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Rear disc w/4 lug???
Old 11-23-2011, 04:25 PM
MrMug3n's Avatar
Default Rear disc w/4 lug???
Is this an option? I would realy like to upgrade to disc brakes without giving up the $2000 wheels I just bought...
Old 11-23-2011, 04:50 PM
lazlong's Avatar
Default Re: Rear disc w/4 lug???
2002-2003 SI (EP3) have 4 lug.
Old 11-23-2011, 05:34 PM
eghatch4sale's Avatar
My Acura el has rear disc breaks
Old 11-23-2011, 07:23 PM
bsyeth's Avatar
Ep3 rears would be a hard find, and unless your close to Canada, acura EL would cost to get shipped, not to mention the rust.
But I would like this upgrade too.
Old 11-23-2011, 08:41 PM
Plead da Fif
It Wasn't Me's Avatar
Please read the FAQ's before you make a thread.
Rear Disc Brake Installation: Link
Old 11-23-2011, 10:16 PM
Sanji
toyomatt84's Avatar
EP3 rear brakes are far from difficult to find. There were a ton of them out there, and a lot of EP3 owners who still have 4-lug upgrade to the more modern 5-lug setup.
Old 11-24-2011, 07:12 PM
eviee1973's Avatar
If you can find a five lug rear disc swap set, you should be able to convert the five bolt wheel bearing and hub assembly to a four bolt, along with changing the five bolt rotor to a four bolt rotor. I believe everything else (spindle, caliper, and caliper bracket should be the same) You could likely find white box rotors and wheel bearings for under $200 usd.
Old 11-26-2011, 02:25 PM
ourbloodykisses's Avatar
yeah cant you just knock out the hub and switch them?
Old 11-26-2011, 07:52 PM
metalviper's Avatar
remove & replace the 5 lug hub...yes
Old 11-27-2011, 06:03 AM
thats what I had planned, dont feel the need to do the rear disc. I dont drive fast
Old 12-03-2011, 11:44 AM
MrMug3n's Avatar
good to know guys THX
Old 12-04-2011, 12:59 PM
2005AcuraEL's Avatar
Yeah the Acura EL has rear disc, shouldn't be too hard to find a parts car. Several of them in the junkyards near here (Newfoundland).
Old 12-04-2011, 01:35 PM
Plead da Fif
Newfoundland ≠ Florida
Acura EL is not a common vehicle in the states, and it simply wouldn't be worth the cost alone of shipping the parts from Newfoundland-to-Florida. Better off using EP3.
Old 12-04-2011, 01:40 PM
Dima1127's Avatar
its been done many time....
just use the EP3 rear breaks....
pinoyboy204
06-25-2012 04:32 PM
GoobyEP3
10-05-2007 05:14 PM
joey_06_2004
04-04-2007 10:25 AM
RJayS.
08-18-2006 03:43 PM
Quick Reply: Rear disc w/4 lug???
