Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Civic Ex Cylinder 2 and Cylinder 4 Misfire
Old 03-19-2017, 05:29 PM
Jvega1691's Avatar
Default 2001 Civic Ex Cylinder 2 and Cylinder 4 Misfire
I jus got a 2001 Civic Ex with Cylinder 2 and cylinder 4 are misfiring. When I test drove it the check engine light wasn't on about 2 miles later it popped up. I replaced the spark plugs it turned off for about 25 mins then went back on. Any ideas what it could be?
Old 03-20-2017, 08:56 AM
NDNV's Avatar
Default Re: 2001 Civic Ex Cylinder 2 and Cylinder 4 Misfire
Use only OEM NGK plugs.
Old 03-20-2017, 04:52 PM
Jvega1691's Avatar
Yeah they are, gonna see and change the ignition coils next hopefully that will help
Old 03-21-2017, 03:48 AM
NDNV's Avatar
It may only be one coil so test them all first before replacing them all.
Old 03-23-2017, 07:51 PM
bbarbulo's Avatar
so is the plan to keep replacing parts? or at what point does one start troubleshooting? assuming you don't own any diagnostic equipment, at the very least logic would dictate to take coils 1 and 3 and swap them to cylinders 2 and 4. if the misfire returns to cylinders 2 and 4, we can safely assume the coils are not to blame? yes? yes.
Old 03-25-2017, 10:24 AM
Jvega1691's Avatar
went too 2 different mechanics one said my head needed a new gasket and vavles and was leaking. Next I went too another well known shop and they said the engine is basically going. All that can be done is too drive it till it goes out. Seems all can be done now is buy a new engine from Jdm and have it swapped. We unplugged each coil while the car was on there were all working, brand new coils, we unplugged injectors too and same there, I jus bought the car I am not paying for any of this the person bought from is.
wheels49
03-03-2013 02:21 PM
Wwisuri
01-28-2013 10:47 AM
bsconz
09-20-2012 06:10 AM
qinfujun
09-23-2011 03:10 PM
kopaj612
03-30-2008 04:16 AM
Quick Reply: 2001 Civic Ex Cylinder 2 and Cylinder 4 Misfire
