Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
over-revved, runs poorly, diagnostics
Old 11-30-2011, 09:43 AM
ryder_kid's Avatar
Default over-revved, runs poorly, diagnostics
Hey friends, I have an 04 accord ex coupe, v6 motor. recently 4 weeks ago I did the valve adjustment-- she ran fine afterward, no noise, etc. I put in new ngk iridium plugs, all effected top end gaskets, oil and filter (always mobil 1, 5w-20)..
upon Thanksgiving highway travel, I was getting off at an exit and mis shifted (over revving the **** out of the motor for about 2 seconds before I caught it and corrected) now i'm getting seemingly valve chatter and TERRIBLE puttering at idle. (like its fighting for correct air/fuel)
checked the plugs, look new still, compression varied 1 0r 2 pounds, but overall 145 psi across all cyl's (book calls for 135 min, max var. 28 psi)
then I was trying to convince myself it was affected by crappy gas, so I added Lucas injector cleaner, Heet water remover, and for ***** and giggles dumped in a few ounces of Lucas oil additive (to hopefully quiet the lifters?)
for more kicks and giggles I tried doing the ckp relearn procedure as outlined by honda, the CEL went away for a mile or two then came back, the symptoms persisted throughout though
at idle it "hunts" as i call it- kind of gurgling like a alcohol motor.. if i slowly increase rpm's to about 3k then let off immediately the bottom end falls out and then eventually tries to regain, gurgling once more
my worst fear is that I briefly floated the valves-- I hear constantly this is a huge occurence in the j30a4 m/t cars. but wouldn't this suggest a lower compression reading?
should I continue checking tps, map, o2, and iat, etc sensors? or am I spinning my wheels to the inevitable valve cover pull and valve inspection?
any help would be very appreciated!!
Old 12-01-2011, 04:44 PM
motegicivic's Avatar
Default Re: over-revved, runs poorly, diagnostics
You might want to do a leak down test. I am wondering if you spun a bearing.
Do not dump more parts into it, until you test.
And you did the compression, followed all procedures? I would do it again. Over revving is bad news.
Old 12-02-2011, 04:09 AM
Mechanic's Avatar
Your's is an "interference" engine, meaning one or more pistons will strike and bend open valves if you signficantly over-rev the engine. $$
Old 12-02-2011, 04:19 AM
scottdh20's Avatar
but if he bent valves he'd lose compression in the cyl with bent valves
do a leakdown, double check compression and follow the instructions, check oil for oil shavings, check vacume lines(spray carb cleaner at vac lines) idle surging can be caused by a vac leak....and double check that you dont have hairline cracks in the porciline of the plugs
Old 12-03-2011, 02:49 PM
DCFIVER's Avatar
The valves are bent...
Old 12-10-2011, 11:41 PM
asnstyle22's Avatar
doesnt the car do fuel cut @ redline? how can you super over rev?
Old 12-10-2011, 11:52 PM
lazlong's Avatar
HA! Just ask half the owners in any of the forums. A lot of people have done it. It happens.
Old 12-11-2011, 04:11 PM
DCFIVER's Avatar
A fuel cut cannot prevent a mechanical over rev.
Old 01-14-2012, 01:53 AM
jakefrom's Avatar
Just outta curiousity how high did you over rev?? Like 8k plus??
Old 01-16-2012, 12:05 PM
Unless you have an auto trans
Old 01-16-2012, 12:48 PM
Tmfw's Avatar
Sounds like a bent valve to me
Old 01-16-2012, 01:56 PM
GDD's Dr. Phil?
oneludesol's Avatar
check the valve lash, I have seen them go all over the place after an over-rev
Old 01-16-2012, 08:26 PM
DCFIVER's Avatar
Huh? A fuel cut will not prevent a mechanical over rev,even with an auto transmission.
Old 01-19-2012, 11:42 PM
dcgogettem's Avatar
What did your check light come on for? If its your cpk and random misfires detected at multiple cylinder banks you either jumped timing or your crank position sensor took a crap
Old 01-30-2012, 12:05 PM
IntenseDriving00's Avatar
Common problem on these are bent valves from over reving. Very sensitive interference engine.
Old 02-04-2012, 10:17 PM
D-JET's Avatar
To check if you got an engine/compression problem. get a simple vacuum gauge and the reading should be between 18-21" Hg with a steady needle. Check at idle and also at 2000 rpms.
NerfGunner420
06-06-2019 04:32 PM
stancedegcivic
02-11-2013 08:23 AM
tobytigger
09-26-2012 10:31 PM
nkmndz
02-25-2012 05:12 AM
goowakjai
05-02-2005 06:10 PM
Quick Reply: over-revved, runs poorly, diagnostics
