Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
How to remove 2005 Accord windshield washer nozzles?
Old 10-02-2015, 08:15 AM
bakkouz's Avatar
Default How to remove 2005 Accord windshield washer nozzles?
Hello,
I have a 2005 Accord EX. the windshield washer nozzle on the drivers side doesn't work (no water comes out at all) the one at the passengers side works just fine. I tried poking it with a needle but nothing happened. and as i don't have anything i could use to blow pressurized air into it or anything, i thought I'd remove it and check the tube and all that, but the problem is that i can't see a clear way of doing that. the nozzle is built right into the plastic frame, do i really need to remove the whole frame just to check the nozzle and tube? If so, how do i even do that? i have no idea. any thoughts?
I've attached a photo for reference.?
Old 10-02-2015, 11:27 AM
ekb16's Avatar
Default Re: How to remove 2005 Accord windshield washer nozzles?
the washer nozzle is not part of the cowl. just find yourself a small flat head screw driver and gently pry on the edges. you can also remove that piece of cover next to it and use plyers to grab the tabs and put the nozzle out
bass04
03-23-2016 02:51 PM
88ernie88
13
04-05-2009 12:31 AM
JDMRedH
05-17-2008 06:55 AM
yomayo
11-22-2006 05:11 PM
Quick Reply: How to remove 2005 Accord windshield washer nozzles?
