Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2006 Honda Accord Coupe Can't Open Door!?
Old 11-01-2013, 08:52 AM
digihonda's Avatar
Icon2 2006 Honda Accord Coupe Can't Open Door!?
Hi all, this morning I was going to open the drivers side door to my 06 Coupe and it just won't open. Nothing is stuck in it, the lock seems to be operating properly, but it feels as if the door handle is disconnected from the lock mechanism and is permanently locked now(better than unlicks, right)..
I have to climb in from the passenger side, which, is not fun and rather embarrassing in a parking lot full of fully operable driver side doors... any ideas? anyone else experience this?
Old 11-01-2013, 03:18 PM
Lost Again's Avatar
Default Re: 2006 Honda Accord Coupe Can't Open Door!?
Once inside, can you manually unlock the door and then either open it from the inside or outside?
Old 11-04-2013, 05:28 AM
digihonda's Avatar
No, which is why I decided to start a thread... I can't open the door from the inside either, which leads me to believe I may have a broken cable? Going to have to pop the door panels off more than likely..
Old 11-04-2013, 12:59 PM
BLKFLSH's Avatar
I've never had to do it, and you can bet it's not fun, but yes you will have to get the door panel off.
Old 11-04-2013, 01:07 PM
jdmh22eg2's Avatar
my money is on a door lock acuator
Old 11-04-2013, 06:38 PM
BLKFLSH's Avatar
Good point. I thought there was a cable for the inside handle, and a rod for the outside handle. Hard to believe both came loose/broke at the same time. Did you try using the physical key itself, to unlock the door from the outside?
Old 11-04-2013, 07:25 PM
jdmh22eg2's Avatar
well i am speaking from a dealer tech from another brand car and we have same issues (couple models) and they usually fail from one side but sometimes both. but to save yourself some cash take the panel off and see if any thing has came loose first
Scott Younker
05-28-2019 07:33 PM
rubenmed
11-25-2012 01:46 AM
JDMEK108
06-14-2010 01:07 PM
hondaaccordingly
03-02-2009 07:18 AM
Quick Reply: 2006 Honda Accord Coupe Can't Open Door!?
