Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 Honda accord power socket in arm rest box dead
Old 05-24-2016, 03:26 PM
coccolith's Avatar
Default 2007 Honda accord power socket in arm rest box dead
I am looking for the fuse for this power socket in arm rest box.
But I cant. just find the fuse for front one. Anyone know that.
Thanks in advance
Old 05-24-2016, 03:43 PM
poorman212's Avatar
Default Re: 2007 Honda accord power socket in arm rest box dead
The two share the same fuse and relay. So if one is not working, a little more investigation is going to be needed.
Old 05-24-2016, 03:50 PM
coccolith's Avatar
Thank you very much for your response.
If so, it is an impossible task for me.
Old 05-24-2016, 03:59 PM
poorman212's Avatar
Shouldn't be....there is like one screw holding the "panel" in there (my 07 EXL isn't home right now so just using the service manual). Once remove the panel will come out, then there are two wires, unplug those and verify power and ground with a volt meter. If you have that....the socket is dead and needs to be replaced.
Now if power or ground is missing, it gets a tad bit more complicated but nothing that bad.
Old 05-24-2016, 04:20 PM
coccolith's Avatar
I really appreciate your help. But what the panel you refer to?
Old 05-26-2016, 01:29 AM
poorman212's Avatar
In the center console, there should be a small screw holding the "panel" in.
crist488
10-10-2009 09:45 AM
ExVtec
Honda S2000
17
03-18-2009 05:19 PM
jmccalip
03-11-2009 01:54 PM
R7000
01-04-2009 12:10 PM
vtecn8ive
08-08-2008 05:32 PM
Quick Reply: 2007 Honda accord power socket in arm rest box dead
