Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2005 Accord EX brake shuttering
Old 10-03-2007, 06:27 AM
aktam's Avatar
Default 2005 Accord EX brake shuttering
Hello,
My 2005 Accord has 31,000 miles and is under warranty. Recently when applying the brake at freeway speed, the steering wheel shakes. Seems that the rotor is warped. Still have about 30-40% left on the pads. Will my rotor replacement be under warranty?
Thanks!
Old 10-03-2007, 06:47 AM
In a Junkyard near you.
Ross 2.0's Avatar
They will machine the rotors under warranty, they should replace the brake pads as well.
Old 10-03-2007, 06:50 AM
DrZFiNeSt's Avatar
Default Re: (Evil Monkey)
Having unbalanced tires could cause your car to do that on the freeway also.
Old 10-03-2007, 06:51 AM
Ross 2.0's Avatar
Default Re: (DrZFiNeSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrZFiNeSt &raquo;</TD></TR><TR><TD CLASS="quote">Having unbalanced tires could cause your car to do that on the freeway also.</TD></TR></TABLE>
not during braking
Old 10-03-2007, 06:52 AM
DrZFiNeSt's Avatar
o **** my bad I didnt read that part....yea it's the rotors dude.
Old 10-05-2007, 12:09 PM
aktam's Avatar
Default Re: (Evil M0nkey)
Thanks for the info.
I took it into the dealsership and was disturbed when they quoted me $125 for inspecting the car if they find that the brake vibration is not caused by the rotors or anything that is not covered by warranty. My arguement was that since the car is under warranty, I should not be charged for inspection regardless of the cause of the problem. Is this normal practice in other dealerships?
Anyway, at the end, they are willing to re-surface the rotors and replace the brake pads.
Old 10-05-2007, 08:47 PM
BrakeExpert's Avatar
Default Re: (aktam)
there being douches. At DEALER cost, its probably cheaper to replace the rotors than resurface them. Hell, any blank aftermarket rotor will do the same. Were your wheels put on correctly and torqued properly?
snaylor
08-26-2017 05:36 AM
theLemur
11-17-2011 06:33 PM
LOWLIFEHATCH
02-22-2004 08:06 AM
MJ23FE
11-19-2002 09:12 AM
Quick Reply: 2005 Accord EX brake shuttering
