where data link connector(DLC) is located for 96 honda accord and what terminals to connect to obtai
Old 09-16-2005, 10:32 AM
frank_O's Avatar
Default where data link connector(DLC) is located for 96 honda accord and what terminals to connect
to obtain the trouble codes. need to find out if i'm getting any ecm or crank position sensor codes. 96 honda accord lx 2.2 non-vtec
Old 09-16-2005, 11:26 AM
Charri's Avatar
Default Re: where data link connector(DLC) is located for 96 honda accord and what terminals to connect (fra
I believe youre talking about the OBDII connector pin? If so, all you have to do is pull out the ash tray and you'll see the connecting harness. Insert reader and you'll get your cold
Old 09-16-2005, 01:32 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frank_O &raquo;</TD></TR><TR><TD CLASS="quote"> to obtain the trouble codes. need to find out if i'm getting any ecm or crank position sensor codes. 96 honda accord lx 2.2 non-vtec</TD></TR></TABLE>
The DLC for an obd2 scantool is behind the ashtray. But there is a service check connector below the glovebox to pull the codes manually.
cos4bama
12-04-2018 09:22 PM
futbolhead
07-25-2007 10:55 AM
Quick Reply: where data link connector(DLC) is located for 96 honda accord and what terminals to connect to obtai
