what do i need to lower my cg5?
Old 04-12-2010, 07:29 PM
beyz's Avatar
Default what do i need to lower my cg5?
i would like to know which is the best brand name to go with when it comes to coilovers/springs?
i have a 2000 honda accord special edition.
thanks
Old 04-12-2010, 08:13 PM
GhostAccord's Avatar
Default Re: what do i need to lower my cg5?
There is a suspention thread in the FAQ's that you could read over. I'm not sure how up to date it is but it should give you a better idea of what to look for.
https://honda-tech.com/forums/honda-accord-1990-2002-2/basic-guide-accords-797528/
& here is a tread with pictures & specs of members suspention setups.
https://honda-tech.com/zerothread/1971782
Old 04-12-2010, 08:25 PM
beyz's Avatar
dope!
thanks. ill check those out!
am i going to be experiencing a lot of rough driving no matter what i use or how much i lower my car?
Old 04-13-2010, 06:16 AM
Not necessarily. There are different spring rates and different styles of shock that will determine your ride quality. Depends on the combination that you choose.
Old 04-13-2010, 08:12 AM
beyz's Avatar
ok, because this will be my daily driver and i want something im going to be comfortable with but at the same time looks hella dope!
i appreciate the help, man.
time to do some research!
thanks
Old 04-13-2010, 09:41 AM
No problem
Old 04-13-2010, 07:29 PM
imbodiedchaos's Avatar
I have heard great things about skunk2s springs and coilovers. Progress (i think thats the company) i have heard recommended. D2s are good. Just depends on what you are looking for. Tein is alot of people's default choice for a nice comfortable ride. If this is your DD then you should look into a simpler setup that'll still give you nice handling and low stance.
Old 04-14-2010, 07:52 AM
beyz's Avatar
true enough my man!
im definitely aiming for the simple set-up. i want a clean looking ride that's good for all seasons (Toronto winters and shitty roads).
thanks for the info too, im considering eibach sportline or tein.
Silent909
Suspension & Brakes
06-30-2014 06:48 PM
jimjonez
02-09-2007 07:59 AM
needashell1234now
Suspension & Brakes
01-27-2007 11:35 AM
BraydenR
Suspension & Brakes
05-13-2005 01:27 PM
Siamese
08-16-2004 07:42 PM
Quick Reply: what do i need to lower my cg5?
