water leaking from a/c evaporator? help!!!
the haynes manual says that there are draining tubes from the evaporator that can become clogged. it says just access the tubes and clear the restriction, but i dont know if i have to remove the dash to get to it. someone with similar problem, please help me locate tubes. thanks
Re: water leaking from a/c evaporator? help!!! (YeuEmMaiMai)
i was under the car yesterday and i noticed a small rubber hose that seemed to be a drain, located near the firewall pass side with little plastic holders, could this be it? thanks
Just a suggestion to clean them out, I did this with my central A/C in my house, it was clogged. So I took a shop vac and a wet rag. You place the shop vac hose over the tube, and then seal it to the tube with the wet rag and turn it on, anything blocking the tube will be sucked out. Works pretty good.
Good luck!
Good luck!
Life is Suffering
Re: water leaking from a/c evaporator? help!!! (briq4)
Good luck!
Good luck!
Re: water leaking from a/c evaporator? help!!! (gringo7718)
[Modified by p0pe, 1:39 PM 6/24/2002]
