Trans fluid change?
Old 02-24-2011, 03:20 PM
bmclean1's Avatar
Default Trans fluid change?
Wondering if I will kill my tranny if I change out the fluid. Its a 96 auto with 189K on it and I have no idea if the fluid has ever been changed. I've heard all the myths about not changing old fluid because the new fluid will kill your tranny.
Anyone do a high mile fluid change with good results? I was gonna use the honda z1 to do a drain and fill.
So, any suggestions?
Old 02-24-2011, 04:31 PM
19Accord97's Avatar
Default Re: Trans fluid change?
Why would changing fluid hurt anything? All old fluid does is circulate particles that act as an abrasive and do more damage. Replace the fluid asap.
Remove dipstick for tranny
Remove plug
Drain / clean off magnet
Insert plug
Fill up w/ ~ 2.5 quarts of HONDA ATF
Put in dipstick
Drive 50-100 miles and repeat 2 more times.
Old 02-24-2011, 04:49 PM
laloquera916's Avatar
I do a complete tranny flush, never had any problems. I dont do the drip and fill thing. Utube has a good vid. on DYI flush on 2001 accord.
Good luck.
Old 02-24-2011, 07:52 PM
Jmb106jr's Avatar
Remove plug
Insert plug
Put in dipstick
I second that!
Old 02-24-2011, 08:03 PM
Jmb106jr's Avatar
I bought a 1 Owner 95 Accord w/ 206k on it, when i got it home and changed the fluid it was Brown & Gritty. 3 drain and fills its nice and red. It now has 240k gets a drain and fill every other oil change and shifts perfectly! I personally use Valvoline Maxlife ATF. I Have used it in 4 different Honda's and a Nissan w/ out any issuses.
Joe
Tmilli55
Honda CR-V & Element
09-26-2018 01:27 PM
dankoty
11
01-08-2017 03:38 PM
JennyPooh
40
11-04-2010 11:17 PM
kornerk12
11-18-2005 05:37 AM
typer_801
02-05-2002 09:29 AM
Quick Reply: Trans fluid change?
