thermostat does not open...
Old 08-31-2016, 06:43 AM
dishjuarez's Avatar
Default thermostat does not open...
I have a problem (ok. Not if it's a problem. Because the panel say optimum temperature). the upper radiator hose is heated to bubble. but the thermostat does not open. and the lower hose is cold. I have no hot air in the heating. and change the thermostat and antifreeze. can you help me please?
Old 08-31-2016, 10:52 AM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: thermostat does not open...
Since you did not state what year/sub-model/engine/region your car is, I'm going to guess you have some version of Accord with the F series 4cylinder engine.
When you drained/refilled your coolant, did you bleed/purge the cooling system of air using the bleeder screw on the thermostat housing?
If not then the car will never properly warm up and the thermostat will never open. But your temp gauge may peg and you may blow your head gasket if you are not careful.
Old 08-31-2016, 12:01 PM
holmesnmanny's Avatar
open the bleeder bolt for a few seconds
jackhis
06-18-2022 10:26 PM
willfly
12-30-2013 09:44 PM
KidZr0
19
09-01-2011 01:28 PM
blinger
05-14-2007 06:39 PM
Veleno
15
03-14-2005 09:03 PM
Quick Reply: thermostat does not open...
