TAS Tech Tip: Inner Door Handle Replacement
Old 08-08-2008, 10:12 AM
Banned
TASAuto.com's Avatar
Default TAS Tech Tip: Inner Door Handle Replacement
Accord Door Handle Installation
The following instructions are merely one suggested method for installation. There are other ways to properly install your inner door handle. T.A.S. Auto Parts is not responsible for faulty installations. Labor claims will not be acknowledged. If you are not familiar with the processes listed below, please seek the help of a professional automotive technician.
1. For this tech tip we will be using the front passenger door on a 97 EX.
2. Start by prying open the screw cover on the handle.
3. Use a phillips head screwdriver to remove the screw.
4. Gently pull the door handle forward towards the front of the car, then inward away from the door panel.
5. Unplug the wire harnesses by pushing down on the clips.
6. Using a flathead screwdriver push the clip off of the rod and pop the rod up out of the handle.
7. Using a phillips head screwdriver remove the switches that are held in with 4 screws and install them on the new door handle.
8. Plug the wires for the window switch and the door locks into the new door handle.
9. Install the lock rod and push the clip back into place.
10. Install the new handle into the door panel.
11. Lock the handle into the inner door panel by pushing it back towards the rear of the car.
12. Re-install the retaining screw and put the screw cover back in place.
Modified by TASAuto.com at 8:29 AM 8/13/2008
Old 08-08-2008, 09:21 PM
SuShiBoiiii's Avatar
Default Re: TAS Tech Tip: Inner Door Handle Replacement (TASAuto.com)
thanks
Old 08-09-2008, 01:42 AM
hondarazor23's Avatar
Location: You may think I can't see you..but in reality..I could see you very clearly..
Default Re: TAS Tech Tip: Inner Door Handle Replacement (SuShiBoiiii)
nice...im thinkin bout gettin one of those cuz on one of em the chrome is peeling off da handle
Old 08-11-2008, 12:36 PM
sfcd5's Avatar
thnx for the tutorial i was meaning to replace my cracked handle.
Old 09-03-2008, 09:18 AM
Banned
Default Re: (sfcd5)
anyone want to add this to the FAQ index ...it is good info to have
Old 09-03-2008, 10:09 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: (TASAuto.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TASAuto.com &raquo;</TD></TR><TR><TD CLASS="quote">anyone want to add this to the FAQ index ...it is good info to have</TD></TR></TABLE>
Old 09-17-2008, 09:39 AM
Banned
Default Re: (TouringAccord)
note: be very careful with the purple rod clip because they can be very brittle
Old 09-17-2008, 01:14 PM
reydio's Avatar
Awesome, great information......now, just gotta find a replacement screw cover.....mine cracked and came off....its ugly without the cover.
Hyard24
Audio / Security / Video
01-16-2008 08:12 AM
tom48
10-17-2007 09:05 PM
pstanger
08-22-2007 08:58 AM
Matt300ZXT
06-06-2007 06:12 PM
businessmanph
10-30-2005 10:45 PM
Quick Reply: TAS Tech Tip: Inner Door Handle Replacement
