how to remove needles from gauge cluster
Old 10-31-2005, 07:40 PM
aws140's Avatar
Default how to remove needles from gauge cluster
how do i get the needles off of my gauges? i need to get my speedo out and i couldnt get the meedle off. i figured you just pulled it straight out but it didnt budge and i didnt want to risk breaking it.
94 LX 5sp 4dr
thanks
Old 10-31-2005, 07:58 PM
P_Adams's Avatar
Default Re: how to remove needles from gauge cluster (aws140)
That's it in a nut shell. The trick comes when it's time to put them on again. Now how did they align on that shaft??
P
Old 10-31-2005, 08:32 PM
momstaxi's Avatar
i believe you have to replace the entire gauge assembly within the cluster...ive never heard of removing the needles themselves...
Old 10-31-2005, 08:52 PM
iam7head's Avatar
Default Re: how to remove needles from gauge cluster (momstaxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi &raquo;</TD></TR><TR><TD CLASS="quote">i believe you have to replace the entire gauge assembly within the cluster...ive never heard of removing the needles themselves...</TD></TR></TABLE>
some can be remove like the 6th genaccord and 5th gen prelude but putting it back is another problem, sometime when you put it back, the needle jerks and stuck.
what exactly do you want to do?
Old 10-31-2005, 09:00 PM
dtran002's Avatar
yea u have a 94 accord, it wont come out, believe me, i tried and fawk, i broke the damn needle... good thing i found a replacement for 50buk lol
Old 11-01-2005, 12:16 PM
aws140's Avatar
i need to take the speedo from one gauge cluster and put it in another gauge cluster. the one that works the brake light and other ones like that dont work. and the mileage is incorrect.
Old 11-01-2005, 04:40 PM
RiceRocketDave's Avatar
Default Re: (aws140)
There are a few gold screws on the back of the cluster just remove them and the whole speedo assembly will come out
You DO NOT NEED TO REMOVE THE NEEDLE TO DO THIS!!!!!!! You will damage the speedo assembly beyond repair if you attempt to.
http://www.hondaautomotivepart...NENTS
Old 11-01-2005, 06:52 PM
aws140's Avatar
Default Re: (ricerocketdave)
thanks il try that and see how it goes
Old 11-01-2005, 06:54 PM
0x5359-0055
213374U's Avatar
VERY CAREFULLY
Old 11-01-2005, 07:02 PM
Jared24's Avatar
I actualy need a temp and fuel guage peice with needle and all for my 96. What year are the parts in the link selling the cluster parts? Both of the needles broke off on those two peices and u cant replace them as far as I know.
Old 11-01-2005, 11:21 PM
Chyno's Avatar
Default Re: (Jared24)
hahaha good luck removing the needles because is going to break! you can remove the speed needle and the tach needle but if you try remobing the temperature and gas it will snap like in a seconds!!
Old 11-02-2005, 03:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared24 &raquo;</TD></TR><TR><TD CLASS="quote">I actualy need a temp and fuel guage peice with needle and all for my 96. What year are the parts in the link selling the cluster parts? Both of the needles broke off on those two peices and u cant replace them as far as I know. </TD></TR></TABLE>
I believe I did a search on a 94, but they are all the same from 94-97, the only difference in the clusters is the automatic tranny lights in the middle between the tach and speedo.
Just remember to remove and install all these components you <U>DO NOT HAVE TO REMOVE THE NEEDLES. </U>
Old 11-03-2005, 01:10 PM
aws140's Avatar
i just took the speedo out using the back bolts. very very simple. i just wish i could seperate the speedo from the odometer, oh well. its not that big of a deal. i know what the difference is. now whenever i have time ill take the cluster out of my car and switch the speedos and clusters. thanks
Old 11-03-2005, 06:28 PM
IM me if you need help removing the cluster.
Old 11-03-2005, 08:06 PM
aws140's Avatar
thanks ricerrocket. youre a major help. i already took the cluster out once. the only reason im doing it again is cause the cluster i put in certain lights dont work(ex:gas, seat belt, brake) so im just going to stick the good speedo in my old cluster that everything else worked in. thanks a lot for all your help though
Old 11-04-2005, 03:26 AM
No problem, You know that those lights that are not working are just light bulbs that you can get from any auto parts store. You may just wanna replace those and save a few bucks from having to purchase a whole new ins. cluster.
Old 11-04-2005, 09:42 AM
H22akkord23's Avatar
haha, i remember when a friend of mine tried to remove the needles on his daughters car, after i told him they dont come out, he said...o i know what im doing....i laughed and sat there
next thing he says is "damn, it broke"...i busted into an histarical laugh, but....im glad you got it apart and got some advice before you broke the needles....
Old 10-10-2014, 05:29 PM
The_eazyCD5's Avatar
Hey guys I know you said the needle won't come off, but i want to know is there anyway I can get the face of the gauge off without taking the needle off? My needles won't budge so I'm not gonna force them off and break them. The reason I want the gauge face is so I can remove the blue tint on the back in order for me to get different color LED lights in and not make it look blue in any way possible.
AcuraIntegra_19_94
01-25-2009 10:25 PM
ferrarifreak93
06-05-2005 10:32 PM
joshmarlette
10-08-2004 06:25 PM
Mrfeee1
21
12-10-2003 08:09 AM
Quick Reply: how to remove needles from gauge cluster
