Starter stuck....
Old 01-31-2008, 10:26 PM
Charri's Avatar
Default Starter stuck....
97 Honda Accord SE Automatic
Starter stuck....
1. tried rolling car
2. hitting starter
3. what am I to do?
Well yeah starter got stuck. Is there any other tricks other than the ones I've stated. Last resort take it out and re-install.
Old 02-01-2008, 03:58 PM
Charri's Avatar
Default Re: Starter stuck.... (Charri)
car not starting bump
Old 02-01-2008, 06:09 PM
sony224422's Avatar
how did it get stuck.. is your battery dead?
have someone start the car while you hit the starter.
after that, get a new one or new contacts for inside it.
Old 02-02-2008, 03:30 PM
Charri's Avatar
Default Re: Starter stuck.... (sony224422)
So I take out the starter get it tested it passes just fine terminals are good
battery was good
On the flywheel....theres this bulge/wedge of metal on the flywheel its on top of the Torque converter Im assuming this is what stopped the car from cranking over. Went to Autozone they gave me a new starter just in case. Is the wedge on the flywheel going to cause the same problem for me?
Old 02-02-2008, 05:31 PM
The-Kid's Avatar
Well I just replaced my starter today on my Auto 96 Accord. There shouldn't be any buldges of metal on the flywheel gears. Everything on the flywheel gears should be clear. If you are talking about a weld, I had that too near the torque converter. So that is normal. I'll try to post a picture of the inside of the starter hole.
Old 02-02-2008, 06:12 PM
Charri's Avatar
Default Re: Starter stuck.... (The-Kid)
I was about to freak out because of that little piece of weld.
Old 02-03-2008, 01:49 PM
sony224422's Avatar
how are the teeth on the starter and flexplate? are you sure they are aligned right? no broken or really worn teeth?
Old 02-04-2008, 10:07 AM
Charri's Avatar
Starter is brand new
flex plate straight.....
teeth on flywheel are not missing nor worn down.
Well I put in the starter a yesterday now my car wont crank at all. Im going to try replacing the jumper wire from starter ground and starter power wires to the battery. I know the starter is fine I tested it when it was new just to be sure because I dont like pulling out starters on Hondas.
Old 02-04-2008, 12:42 PM
sony224422's Avatar
yeah you might have a bad ground somewhere.. from either the battery to the chassi somewhere or to the starter. I know i had a problem with the positive on my car, it corroded almost the whole cable.
Old 02-04-2008, 02:41 PM
Charri's Avatar
checked out the terminal earlier the copper wiring was corroded where it meets the terminals where it just became brittle and wiring were breaking off. I'm just going to replace the power and ground wires to the starter to battery. Looking at the copper wiring it looks like it got corroded all the way within the wiring itself where it is covered with electrical tape. Probably why. I'll check out the voltage when I get home from work with my multimeter.
Whiteranger
05-27-2013 06:39 AM
GoneImport
02-18-2008 06:45 AM
383chevy
01-25-2007 07:58 PM
g2homboi
07-02-2004 11:27 AM
Quick Reply: Starter stuck....
