starter removal--94 auto accord
Old 03-29-2008, 11:28 AM
mars's Avatar
Default starter removal--94 auto accord
Hi everyone. I have a little problem when I try to remove the starter out from my car. There are some electrical connection as I shown in the red circle in the pics. How can I disconnect it to take out the starter? Do I just pull it out or twist it? I have removed the bolts already just need to remove this connection to take out the starter. Please help. Thanks.
Old 03-29-2008, 03:54 PM
hondadude's Avatar
Default Re: starter removal--94 auto accord (mars)
one wire should be the starter solenoid wire [black/white stripe] it is just a pull off connection.
The other wire is the battery lead, under a rubber boot.
Unhook the battery negative lead, then peel back that big rubber boot on the starter and there is a 12mm nut holding the battery lead to the starter connection.
Old 03-29-2008, 11:08 PM
mars's Avatar
thanks hondadude. This is my first time to remove a starter. So just want to make sure not to break anything stupid.
Old 03-30-2008, 10:11 AM
mars's Avatar
I have just removed everything. Is there any special way to take out the starter? The space seems very tight to take it out.
Old 03-30-2008, 04:17 PM
mars's Avatar
any ideas of how to take out the starter from such a crowd engine bay?
miguey310
06-23-2010 06:14 PM
tlovaj
08-23-2007 04:17 PM
B bOy CrAyOn
08-06-2007 07:24 PM
GoodEyeSniper
17
09-08-2006 11:31 PM
Chairman Kaga
10-28-2002 04:23 PM
Quick Reply: starter removal--94 auto accord
