WOW major trans problem
Old 03-15-2011, 03:39 PM
FastF22B2's Avatar
Icon6 WOW major trans problem
k my CD5 just did somethin i thought was not gona happen for a while longer well i was coming home from dropin off a homie at work an i was 5 mins away from home when my trans went from 4th gear to 2nd gear so i thought it was the solenoids so i clean them an no so i did a trans flush it needed it an still nothin so im stuck on what to do cuold it be the trans computer or somethin else any help will do
Old 03-15-2011, 04:57 PM
accordmatt's Avatar
Default Re: WOW major trans problem
how many miles on that tranny?
Old 03-15-2011, 09:34 PM
Balwin's Avatar
Mine did this.
I didnt really care though because I changed it to manual.
Its a common problem for mid90s low 00s auto hondas.
Old 03-15-2011, 11:43 PM
FastF22B2's Avatar
0ver 175xxx on the tranny i think yea it has over that much. k balwin yea i know manual is better but family frist then my CD5 so i guess it a problem i cant fix for know cuz if i cant fix it i got to let it go an i really dont want to so any info will help
Old 03-15-2011, 11:58 PM
MM Gruppe B
MAD_MIKE's Avatar
Originally Posted by FastF22B2
any info will help
The AT has two shaft speed sensors, and the speedometer sensor. If either becomes contaminated with ferrous particles(they are magnets) it may send an erroneous speed signal to the TCU and it may command an up or down shift.
Old 03-16-2011, 03:13 PM
Balwin's Avatar
0ver 175xxx on the tranny i think yea it has over that much. k balwin yea i know manual is better but family frist then my CD5 so i guess it a problem i cant fix for know cuz if i cant fix it i got to ket it go an i really dont want to so any info will help
I would start by doing a fluid change and checking to see if the TCU is throwing any codes.
Also do what MAD_MIKE said and clean the sensors.
Old 03-16-2011, 04:40 PM
FastF22B2's Avatar
k i clean the sensors. how do i check the tcu i know how to check the ecu so how do i do the trans computer
Old 03-16-2011, 05:22 PM
Balwin's Avatar
What year is your accord?
Umm.. do you have a check engine light?
Old 03-18-2011, 09:10 AM
FastF22B2's Avatar
its a 94 an no check engine light
Old 03-19-2011, 04:03 PM
mherrcat's Avatar
Not an expert here by any means, but maybe check the throttle control cable to the transmission? I just replaced mine and after adjusting it this made a huge difference in the shifting.
vyeguy
Honda Civic (2001 - 2005)
10-20-2010 06:09 PM
littledude56
09-20-2009 06:54 AM
Nate13
12
02-03-2009 07:52 PM
u'llsee
Acura TL, RL & ZDX
01-16-2006 06:35 PM
Quick Reply: WOW major trans problem
