Resetting the ECU
Old 05-31-2002, 07:02 AM
ts9790147's Avatar
Default Resetting the ECU
Hey Guys
I just put on a whle bunch of mods on my 1990 Honda Accord LX and I was wondering which way is the best way to reset the ECU
I have read that you leave the car running and then pull the backup fuse then shut it off and turn it back on and run idle.
Which is the proper way to reset the ECU. Does disconnecting the battery really work??
Can someone tell me in detail how to reset the ECU and the best way???
Thanks
SOHCArchangel's Avatar
Default Re: Resetting the ECU (ts9790147)
pull the fuse and disconnect the battery, leave for 5 minuites, reconnect.....
Old 05-31-2002, 08:49 AM
New User
Gennady's Avatar
Default Re: Resetting the ECU (SOHCArchangel)
Actually, that doesnt fully reset the ECU. Pull the ECU and Hazard switch fuses.
Also, pulling off the negative terminal cant hurt.
crxsi814
01-18-2011 06:25 PM
eswaroop
04-08-2004 03:37 PM
killa_lude
01-10-2004 12:45 PM
Turbo Powa
11
06-02-2002 09:20 AM
BIGCU
05-23-2002 10:33 PM
Quick Reply: Resetting the ECU
