Replacement Antenna
Replacement Antenna
Antenna starting to show signs of not coming down at all, I need to replace my old antenna and I pretty much do not want to take out the old one, I just want to leave it there. I just have to disconnect it and make sure it dont go up any more.
Anyways
Is there a replacement antenna powerful enough to put it or hide it inside the car?
What options do I have.
Thanks
95 Accord
Anyways
Thanks
95 Accord
Re: Replacement Antenna (bopbop93030)
if your antenna still works, you can just buy the mast at a honda dealer for around 60 bucks. But if your entire antenna assembly is busted, then you're SOL at least for a OEM Honda one....your looking at about 375 bucks! Or you could get an aftermarket one off Ebay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bopbop93030 »</TD></TR><TR><TD CLASS="quote">Mast still works, it just annoying that it will not come all the way down.</TD></TR></TABLE>
You can probably open it up and adjust the motor so that it comes down more and does not stop early.
I found this in the FAQ, the guy made a really good write up;
http://www.freewebs.com/hondad...a.htm
