Removing Old Rotors and replacing new one need instructions
Old 12-13-2005, 08:40 PM
accordisslow's Avatar
Default Removing Old Rotors and replacing new one need instructions
Hey does anyone know or can anyone give me instructions on removing the old rotors off of my car front rotors Non abs? i got the haynes manual but doesnt help much and since they are pressed on will i be able to do in by my self or do i need to take it to a shop? and what kind of tools will i need? and on 1-10 what is the dificulty lever 1 being very easy 10 being "fck it take it to the shop"
Its on a 1994 honda accord lx
Thanks
Old 12-13-2005, 08:44 PM
vtecmw's Avatar
Default Re: Removing Old Rotors and replacing new one need instructions (accordisslow)
I'm in the process of doing mine right now. It's not an easy job. As far as where I stand on how hard it is to do, I'd say an 8.
Here's a good how-to on replacing rotors that will apply to 1990-97 Accords.
https://honda-tech.com/zerothread?id=1281812
Good luck.
Old 12-14-2005, 03:25 AM
Charri's Avatar
Default Re: Removing Old Rotors and replacing new one need instructions (vtecmw)
It also depends on where you live. Say if rust is common it will most likely be a tougher job. That HUB is a PITA when it doesn't want to budge out.
Old 12-14-2005, 08:22 AM
Thanks i appreciate the link! helps alot now im thinking if i should even do it lol.
Old 12-14-2005, 09:08 AM
ilikehonda's Avatar
the hubs are pressed in, so they need to be pressed out
Old 12-14-2005, 12:35 PM
standbackimapro's Avatar
Are you kidding me? I did all of my brakes in an hour
For the front rotors u need a impact gun with a 36mm Socket, take off the big bolt right in the middle of the rotor, you need a slide hammer or other type of hub puller
attach the puller to where the lug nuts would go and start tightning it ( if its the slide hammer) start using the slide hammer, might take a while but ittl come off
Attackman12
07-29-2011 12:17 PM
Sporty2222
Acura TL, RL & ZDX
05-21-2007 02:10 PM
urbanlegend21
09-21-2001 08:32 AM
serious
08-15-2001 12:56 PM
Conechaser
06-30-2001 03:41 AM
Quick Reply: Removing Old Rotors and replacing new one need instructions
