vibration left front
Old 04-22-2011, 06:15 PM
1992honda's Avatar
Default vibration left front
I have a 92 accord w/145k on it. Im having a bad vibration on the left front.
It happens when i accelerate and when turning left when i get of the gas it is smooth as ice. anyone have an idea whats up???
Thanks Brett
Old 04-22-2011, 11:08 PM
holmesnmanny's Avatar
Default Re: vibration left front
If it's a thump, it could be your mount. If it's more of a clicking it could be your cv joint.
Old 04-23-2011, 04:37 AM
Jmb106jr's Avatar
Might be the bearings when under load.
Old 04-23-2011, 09:22 AM
kegobeer's Avatar
It's probably a bad inner CV joint. Replace the axle and you will be good to go. I just swapped my left axle to get rid of some "loose gear" noise and I ended up with vibration under acceleration, which is an indication of a bad or worn inner joint. So, I swapped it again and all is well.
Old 04-25-2011, 10:44 AM
Normally bearings make the same noise no matter which way you have the wheel turned. It only varies based on speed.
Old 05-05-2011, 06:56 AM
1992honda's Avatar
Thanks for the info! But check this out, I lifted the front end and started the car I then turned the wheel left and right and something is binding when I turn left the tranny and engine move in the oppisite direction??????????
Got any ideas.
Thanks for your time Brett
Old 05-05-2011, 02:44 PM
AccordVT's Avatar
Bad inner cv jont, you need a new cv axle.
Old 05-05-2011, 05:24 PM
1992honda's Avatar
Both sides????
Old 05-05-2011, 06:20 PM
kegobeer's Avatar
Sure, that's possible. I'd start by swapping the left front first, since it's the reason why you posted in the first place.
Bush-15
05-26-2009 09:46 AM
LudeJdm
06-02-2005 11:50 PM
pho iz good
03-18-2005 04:48 AM
MOTOCOMPO
09-30-2004 09:26 PM
GReddy SI
12
07-17-2003 04:07 AM
Quick Reply: vibration left front
