High Mileage and Oil
Old 01-09-2010, 09:07 AM
bopbop93030's Avatar
Default High Mileage and Oil
Does High Mileage Engine eat Oil? My Car has Closed to 280,000 miles mostly Freeway Miles and recently I made an Oil change.
Long Story short about a week of driving I check my Oil and its nowhere on the mark on the dip stick, check under the engine no leaks or whatsoever so does this mean that my engine is eating Oil?
Do I need to have the engine rebuilt or replace or is this common for high mileage engine?
Old 01-09-2010, 09:19 AM
He knows where you live!
TheMuffinMan's Avatar
Default Re: High Mileage and Oil
Probably leaking oil or Burning it off
Do you see any oil puddles or grime/oil caked on the motor somewhere? I know my F22 in the beater leaks around the cam shaft seal, valve seal, and oil pan but I'm too lazy to fix yet.
Old 01-09-2010, 10:45 AM
no oil puddles or anything. Is this normal to be burning oil that fast?
Old 01-09-2010, 11:38 AM
fleetw00d's Avatar
I think if you were burning it that fast, you would have the environmental wackos chasing you for the clouds of blue smoke you'd be putting out. Fill the crankcase as necessary, clean the engine, top and bottom (take a floor jack with you to the local self serve car wash late at night, jack it up and spray away, engine cleaner would help). Drive it a bit, then get under it to look for oil leaks. Remember it will tend to flow down and back, so follow oil up and forward.
Pull your plug wires, the spark plug holes may be full of oil, there are seals where the rocker mounts/cam holders mount to the head as well as the ones between the valve cover and head. With that many miles, this is a good bet whether it is your main problem or not.
Check to make sure the seal from the old oil filter didn't stick to the block.
Check the area around the oil pressure switch.
Old 01-09-2010, 11:46 AM
king29's Avatar
try paying less then 10$ and replace the pcv valve
Old 01-09-2010, 12:07 PM
nicolaselias's Avatar
PCV valve = $3 at advance/autozone, pcv gromett $1
What grade of oil you using?
Old 01-09-2010, 12:25 PM
What does a PCV Valve do?
And I use 5w30
Old 01-09-2010, 06:00 PM
plugger's Avatar
What grade oil are you using? A light weight oil in a worn engine will burn oil very quickly; older engines with a moderate amount of wear will do better on heavier "high mileage" formulations.
Old 01-09-2010, 08:56 PM
http://en.wikipedia.org/wiki/PCV_valve
read up man, simple part that can do you the world of good
Old 01-09-2010, 10:16 PM
Is this a fact? I use what is recomended 5W30. So should I use 10W30 instead?
Old 01-10-2010, 12:03 AM
plugger's Avatar
Probably heavier than that. Look for "high mileage formulation" or similar on the label.
Old 01-10-2010, 10:48 AM
king29's Avatar
go to autozone, and look for castrol high mileage formula, and yes stick to 5w-30
Old 01-10-2010, 11:28 AM
TOO MUCH TORQUE's Avatar
use a thicker 5w-30 such as valvoline maxlife syntec blend
Old 01-10-2010, 12:08 PM
Will switching to High Mileage Oil or Thicker Oil work on not the engine to burn oil that fast!
I have to point also that I commute around 100 miles a day! Is this normal for the engine to burn that fast?
Old 01-10-2010, 12:29 PM
davey5300's Avatar
It could be a crank seal problem. My F22b1 has a bad crank seal and I have to fill it up with oil every week
Old 01-11-2010, 02:36 PM
high mileage oils have extra additives for wear protection and has additives that swell up seals to slow/prevent leaks
Old 01-11-2010, 02:59 PM
I'm going to try this Oil on my next Oil Change and see if there's a difference.
Thanks!
diyer
12-11-2010 05:19 PM
globy123
12
10-18-2009 03:01 PM
IntegraRules!
03-18-2007 08:46 AM
servion
06-17-2002 09:36 AM
Quick Reply: High Mileage and Oil
