Brake Rotor replacement spec?
Hey all,
I need a hand from someone with a repair manual. My front rotors are warped and need to be changed, but I want to know whether or not I should replace my rear rotors as well. The info that I'm looking for is the width at which my rotors would need to be replaced.
Also, I'm going to be replacing my pads for mostly street with some auto-x use. Anyone have any good/bad experiences with brembo sport pads?
Re: Brake Rotor replacement spec? (TheMuffinMan)
I got a 94 EX, so I have 1" master cylinder & done ROH
right now I'm using Slotted Brembo blank(98 4cyl accord disk) + Hawks HPS (F&R) for around 8000km or 5000mile
I think HPS is ok for street/daily use
but for auto X i think u need HP plus
never try Brembo pads so can't tell u anything
i order my Brembo blank from this site
its cheap & working fine
http://www.importrp.com/
Re: Brake Rotor replacement spec? (Derek128)
I'm thinking the hawks are going to be a bit extreme for my application. Yes, I want track performance, but I'm not sure how much brake noise I'm willing to tolerate on a daily basis.
Anyway, anybody got rotor replacement specs?
Re: Brake Rotor replacement spec? (propwdialogue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by propwdialogue »</TD></TR><TR><TD CLASS="quote">
Anyway, anybody got rotor replacement specs?</TD></TR></TABLE>
Rear brake Disc Thinkness:
standard: 9.9 -10.1mm (0.39-0.40in)
max refinishing limit: 8.0mm (0.31in)
brake Disc Paralleism: 0.015mm(0.0006in) max
MILANO_RED_CL9
Suspension & Brakes
09-17-2010 11:08 AM
