Ahhh Pwr Window OUT! HELP PLZ!
Old 09-13-2002, 08:59 PM
H22aInside's Avatar
Default Ahhh Pwr Window OUT! HELP PLZ!
my power window just stopped working today. good thing it was alreay up when it quit on me. have any of u guys had this problem.
my passnger side window wont go up but my driver side window works fine . i am assuming that the power window motor just gave out on me.
so can somone plz help me out and let me know exactly what im dealing with.
Old 09-13-2002, 09:00 PM
Life is Suffering
Brandon's Avatar
Default Re: Ahhh Pwr Window OUT! HELP PLZ! (H22aInside)
You need a new regulator. Simple as that.
Old 09-13-2002, 10:09 PM
H22aInside's Avatar
Default Re: Ahhh Pwr Window OUT! HELP PLZ! (B the Turbo Pimp)
im not a pwr window expert....so what is a reg. and is it easy to replace.
Old 09-13-2002, 10:26 PM
Life is Suffering
Brandon's Avatar
It is a black box. It is easy to replace, just take the door panel off.
Old 09-13-2002, 10:46 PM
Jago's Avatar
My window does the same thing. It's anoying
to have to wait forever for your window to go up.
Old 09-14-2002, 01:22 AM
MyBigNut's Avatar
does the passenger side not work at all.... even from the passenger side controls?
if it works from the door controls but not the master controls... i have a fix for that.
Old 09-14-2002, 04:05 AM
UseR's Avatar
Default Re: Ahhh Pwr Window OUT! HELP PLZ! (MyBigNut1)
I have that problem too, but they go slow at times. When it rains it goes a bit faster. My friend had the same problem, but he put electrical tape over the rubber that the glass pulls up through. I was thinking of doing this, but this seems "ghetto-tech." No doubt it will work, but isnt there a spray that and lubricate the rubber?
Old 09-14-2002, 05:40 PM
H22aInside's Avatar
Default Re: Ahhh Pwr Window OUT! HELP PLZ! (UseR)
the passneger side widow wont open at all. both of the controls dont work. i guess i have to replace that reg. thingy.
and an easy way to speed up ur windows is to put armor-all(u know what im trying to spell ) in the window seals and the will go up MUCH faster.
Old 09-15-2002, 02:52 PM
XMarkGuerillaX's Avatar
Default Re: Ahhh Pwr Window OUT! HELP PLZ! (Jago)
yep it sucks
Old 09-15-2002, 10:03 PM
TypeSH's Avatar
Default Re: Ahhh Pwr Window OUT! HELP PLZ! (MarkVoorhees)
is it possible to use the driver side components in the passenger side? I'd love to have the "auto" window switch that the driver side window has (5th gen accord) for the passenger side too. Not to mention my driver side rolls up/down so much quicker than the passenger side.
Old 09-16-2002, 05:12 AM
greensleeper's Avatar
Default Re: Ahhh Pwr Window OUT! HELP PLZ! (TypeSH)
I have a power window module wired up to my alarm. You get remote control of the windows and the one touch up and down from the driver's side controls.
sweet ****.
Old 09-16-2002, 05:51 AM
H-T Order of Merit
TouringAccord's Avatar
https://honda-tech.com/zerothread?id=262914
Old 09-16-2002, 12:27 PM
gringo7718's Avatar
Default Re: Ahhh Pwr Window OUT! HELP PLZ! (TouringAccord)
sounds like your motor is burned out. happened to me last month. just remove door panel and 10mm bolts that hold the window assembly. replace the motor - reinstall. i dont know anything about regulators but in my experience the window just stopped working and it was my motor.
Old 09-16-2002, 12:32 PM
4doorH22's Avatar
I am looking for a bolt-in high-torque high-RPM window motor. Anyone know of any? I want the windows to like cut through stuff.
Old 09-16-2002, 12:35 PM
gringo7718's Avatar
Default Re: Ahhh Pwr Window OUT! HELP PLZ! (4doorH22)
just set up the standard- hampster in a running wheel with the aem pulley system and youll be cutting through seals in no time
Old 09-16-2002, 12:57 PM
KTeller8's Avatar
Default Re: Ahhh Pwr Window OUT! HELP PLZ! (gringo7718)
lol i want the same.. my friends 3000gt flew up.. that he hit the wrong button and it left a darn bruise on my arm.. thats how fast it went up. i wonder if motors and regs.. are universal?? hmmm
Old 09-18-2002, 11:33 AM
chronic's Avatar
you might want to take the switch apart and clean the contacts, I had a similar problem. On mine the drivers side switch would move the passenger side window up fast but the passenger switch would move the window very slowly. I checked took the passenger switch apart and the switch contacts looked burnt, probably from rain that hit the switch when the window was down. I just sanded the burnt part on the copper contacts and it works fine now. So if you window rolls up slow or works intermitently check the contacts because i have had the same problem on 3 different hondas.
Old 09-18-2002, 05:11 PM
4doorH22's Avatar
Default Re: Ahhh Pwr Window OUT! HELP PLZ! (chronic)
Ah, you could be onto something there. I have each interior piece striped to its component parts. I noticed the passenger and both rear window switches were all identical. My passenger window has always been the slow one, so if I swapped (or cleaned) the switch it might speed up, but in my case I think it's more of a friction issue in the window track...
Old 09-18-2002, 05:19 PM
4doorH22's Avatar
Err at least they look identical. Technically if a right side switch were on the left, it'd be upside-down and down would be up and up would be down unless the left side is wired opposite the right side which I think is the case. Haven't tested yet...
Old 09-18-2002, 06:37 PM
boonacka's Avatar
anyone try replacing the motor with a stronger unit off of another vehicle?
Old 09-18-2002, 07:26 PM
New User
BreakStuff's Avatar
Default Re: Ahhh Pwr Window OUT! HELP PLZ! (boonacka)
Please give accurate info when trying to help others out...
You have to determine if the problem is mechanically related or electrically related...
if your window goes "up" or "down" slow, then it is a mechanical problem and can be fixed with some silicone spray or window adjustment.. easy as that!!!! It only becomes a regulator problem if you try to manually force the window up or down, bending the regulator.. the regulator isn't a little little black box!!!.. its that thing that holds the window in position...
on the electrical side of things, you have to determine if the motor is getting a power signal.. plain and simple...
So if we are going to assume here, I'll assume master switch,drivers door wire harness,fuses,cabin harness,passenger side door harness, how about those door jamb connectors that always deteriorate, window run channel,regulator,bad motor,etc,etc... use your heads please!
Old 09-18-2002, 07:28 PM
New User
BreakStuff's Avatar
Default Re: Ahhh Pwr Window OUT! HELP PLZ! (BreakStuff)
oh...I forgot to mention the power window control unit..
Old 09-18-2002, 07:54 PM
4doorH22's Avatar
Yeah. If the motor is not getting power, work backwords from there (electrical). If it is getting power, well, work forwards from there (mechanical)...
Old 09-19-2002, 11:10 AM
TJCCARDCO's Avatar
Use silicone spray to make it go faster
Old 09-19-2002, 11:12 AM
Default Re: Ahhh Pwr Window OUT! HELP PLZ! (TJCCARDCO)
armor all is better.
deerman2701
11-27-2007 05:59 AM
4Dinsaneb16
03-20-2007 01:30 PM
kings1ey
06-20-2005 02:55 PM
.jacob
11
03-03-2003 05:25 AM
io_burn
10-14-2001 08:27 PM
Quick Reply: Ahhh Pwr Window OUT! HELP PLZ!
