Odd Steering wheel allignment?????
My steering wheel seems to change from off center to the left, then to the right throughout the day. Maybe play in the shaft? Could someone help with this problem....I would like to know if this is a major saftey hazard, or just some play in the steering box or rack?
Re: Odd Steering wheel allignment????? (cohenr)
Had the car aligned, It wasn't out of alignment. Tires are wearing perfectly. What I was trying to say is that the steering wheel is sometimes off center to the left, and then sometimes to the right. It seems like there is something loose in the column?
Re: Odd Steering wheel allignment????? (WhoNeedsVtec)
look for tears in the boot and grease sprayed all over everything else. Also check for play in the wheel, jack up the car and shake the wheel top to bottom and front to back, If there is play top to bottom it would be wheel bearings, if its front to back then check the tir rod ends.
Re: Odd Steering wheel allignment????? (smokin rubber)
i asked someone at my local shop i go to, and they said that its my tire balance? he said i just need to balance the tires? what do u guys think?
CDStreetSleeper
03-17-2013 10:34 PM
swizz977
06-07-2010 09:18 AM
95C0upe
18
10-28-2008 06:30 PM
