NEED HELP ACCORD 2000
Old 05-29-2008, 06:24 AM
ruddymart's Avatar
Default NEED HELP ACCORD 2000
Here is my problem. I will appreciate any help I can get.
My Accord 2000 V6 suddenly start working very strange. At first it did not want to start and after few attempts it finally did. Now when I start the car the Idle is fluctuating and it smells awfully on gasoline. I can even see gasoline coming out the mufflers (I think Is gasoline). The temperature gauge does not move at all too. I ran the car for a while but still the temp gauge did not move nor the fans kicked off but when I turn the heat/AC on they start spinning. Checked for error codes and this is what I got.
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Input
P0123 Throttle Position (TP) Sensor Circuit High Input
P1498 Exhaust Gas Recirculation (EGR) Valve Position Sensor Circuit High Voltage
When I reset the codes the check engine comes on again with same error codes.
Please help me
Thank you.
Modified by ruddymart at 9:02 AM 5/29/2008
Old 05-29-2008, 11:26 AM
ruddymart's Avatar
Default Re: NEED HELP ACCORD 2000 (ruddymart)
Anyone??? If it was something simple I will not ask you guys!!
Old 05-29-2008, 11:44 AM
AccordRunner480's Avatar
go to 6thgenaccord.com
younggun90
09-03-2021 12:01 PM
DNGUYEN1904
10-09-2018 07:44 PM
biguglydofys
06-10-2017 04:41 AM
europa
Honda S2000
04-25-2014 10:31 AM
EkS
05-09-2007 01:06 PM
Quick Reply: NEED HELP ACCORD 2000
