My accord leaks oil in the spark plugs
Hello everybody
My 94 Accord LX has a major oil leaks in spark plugs #2 and #3 . I heard that there are some seal need to be replaced , is that correct ? If it does correct the how many seal all together and where are they ?
Thanks in advance for your help .
Re: My accord leaks oil in the spark plugs (boogeidream)
It is strange that the oil only appeared on the uper part of the spark plug where the wire plug in , the inner side of the spark plug are pretty dry , no oil at all .
Anyone have any idea to help me ?
Replace your valve cover gasket and the spark plug grommets, they should be included in a quality gasket set.
And no, it's not strange.
Re: My accord leaks oil in the spark plugs (teamlegacy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamlegacy »</TD></TR><TR><TD CLASS="quote">Replace your valve cover gasket and the spark plug grommets, they should be included in a quality gasket set.
And no, it's not strange.</TD></TR></TABLE>
x2
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boogeidream »</TD></TR><TR><TD CLASS="quote">It is strange that the oil only appeared on the uper part of the spark plug where the wire plug in , the inner side of the spark plug are pretty dry , no oil at all .
Anyone have any idea to help me ?</TD></TR></TABLE>
did you not click on the link ???
if the upper set does not fix the problem you got to replace the lower seals
White Dragon
06-18-2003 08:34 PM
