Mothers 96 Accord, front end roaring, increase with speed
Old 04-01-2011, 05:34 PM
preludebro's Avatar
Default Mothers 96 Accord, front end roaring, increase with speed
The front end of my moms car makes a roaring noise in the front end at higher speed rates. It sounds like the tires are making the roaring noise, but those aren't whats doing it. Shes afraid it's her tranny, but the tranny seems fine. It's smooth, shifts smooth, shifts correctly on time, no fluid leaks. I believe her wheel bearings are bad. Does this sound like a legit problem?
Old 04-01-2011, 05:37 PM
phootbag's Avatar
Default Re: Mothers 96 Accord, front end roaring, increase with speed
Sure. Does the noise change as you CAREFULLY swerve left and right while driving? This loads the bearings and can help pinpoint which bearing is bad.
Old 04-01-2011, 05:44 PM
preludebro's Avatar
Hmm. If I can recall, I do believe it quiets down when she turns or something. I'm not positive, but I'll have her try this and see what happens. Thanks.
Old 04-01-2011, 06:02 PM
singlecamsaint's Avatar
mine hasa similar problem it does it turning right, i changed the driver side bearing and its still doing it. the passensenger side bearing had 0 play in it
Old 04-01-2011, 06:06 PM
phootbag's Avatar
Wheel bearings can be tricky. Since they are a double-race bearing the right bearing can make noise when turning left and vice versa.
The RIGHT way to diagnose this is to raise the vehicle completely off the ground, a shop lift is ideal, and run the car in drive. Increase the wheel speed until you can hear the noisy bearing with a stethescope.
Careful you dont' kill yourself while doing this test.
Old 04-01-2011, 06:10 PM
preludebro's Avatar
Yeah. It sounds like it's the driver side bearing. Stethescope... such a simple idea. lol. Thanks. Good thing theres a shop I can use with a lift. Singlecamsaint, is that your axle?
Old 04-01-2011, 07:14 PM
thats what im thinking or the intermediate shaft i just bought the car so i dont have much of a history... i was goning to just replace the driver side axle and intermeidiate shaft and see what happens
Old 04-04-2011, 05:06 PM
95halx's Avatar
If the noise is still there or gets louder when turning right its the left front bearing and if gets louder when turning left its the right front bearing. hope this helps. Had it happen with mine but I just replaced them both. Noise gone
Old 04-04-2011, 05:13 PM
phootbag's Avatar
Bearings usually make noise because the races get rough spots. You may not be able to measure any "play" in a noisy wheel bearing.
Old 04-05-2011, 03:15 AM
it wasnt my bearings after all, after raising the car on jackstands and running it to 40 mph i had a helper cut the wheel, the passenger side axle started shaking violently, this is the one ill be replacing. OP if you cant find the problem try doing this it helped me tremendously
Old 04-05-2011, 01:59 PM
phootbag's Avatar
Awsome! A bit of diag saves LOTS of money.
fuzzysig
Suspension & Brakes
08-25-2017 12:17 PM
tpatru
10-01-2010 02:55 PM
odo53
05-22-2008 06:30 AM
tunes12
12
08-28-2007 04:54 PM
tunes12
Suspension & Brakes
04-20-2007 02:07 PM
Quick Reply: Mothers 96 Accord, front end roaring, increase with speed
