Prothane vs Energy Suspension motor mounts
Old 06-08-2009, 01:34 PM
accord_raffi's Avatar
Default Prothane vs Energy Suspension motor mounts
Anyone have opinions on who has the better product? I've been trying to look up urethane grades on their websites without luck so i'll call tomorrow. They're closed now I know the debate has gone on about bushings in other sections of honda-tech but I didn't see one for motor mounts.
Old 06-08-2009, 06:35 PM
Default Re: Prothane vs Energy Suspension motor mounts
no one?
Old 06-08-2009, 06:49 PM
He knows where you live!
TheMuffinMan's Avatar
You aren't going to notice a difference between the two.......
Old 06-08-2009, 07:48 PM
uberEFtuner's Avatar
Energy Suspension: Made is USA, two decades of experience
Prothane: founded in 1991
I have energy suspension trailing arm bushings in my 91 civic hatch and have had no problems. Whichever you go with I would recommend the black bushings, they say that its impregnated with graphite to reduce squeaking.
Old 06-08-2009, 08:09 PM
GhostAccord's Avatar
If Prothane was founded in 91 then they too are only 2 years short of 2 decades...lol
I have the ES full kit. Before I purchased them I read a fair number of reviews. They all said that both are pretty much the same and to go with the black ones. For the same reasons that uberEFtuner mentioned.
Old 06-09-2009, 11:03 AM
do you guys have any idea what level of urethane they use? I was debating between these inserts since they're cheap and the mounts made by explicit speed....only thing is the explicit speed mount kits don't have the front mount and that's the one I think went bad.
Old 06-09-2009, 11:45 AM
If your plans are to use the ES inserts to fix a worn out mount, it isn't advised. According to ES you need to have a good working mount in order to use their inserts. IMO if you use an insert on a broken or worn out OEM mount your taking your chances.
Old 06-09-2009, 12:34 PM
ef-hatchcrap's Avatar
when you get insert you only get the front mount insert. I just bought one and it made a big diffrence and your mounts must be in good shape not cracks or tears.
Protthane and es are the company
Old 06-09-2009, 12:57 PM
ya i should have mentioned i planned on getting a new mount too.
madracer
Suspension & Brakes
10
10-25-2008 02:29 PM
biggmike2
03-29-2004 07:34 PM
ryan12321
02-28-2003 10:15 PM
Quick Reply: Prothane vs Energy Suspension motor mounts
