misfire erg
Old 09-02-2015, 05:19 PM
princesa0504's Avatar
Post misfire erg
i got a 98 honda accord v6 with like 197,000 on it. When the check engine light comes on i get it checked and its usually misfire in 1-6 cylinders along with a random misfire, i changed spark plugs, wires distributor cap and rotor button, didnt solve my issue tho because it still is misfiring. Then it came on again, this time my transmission went out and i replaced that but still misfires. Then alternator went out replaced that well now this is the first time ive seen codes for catalytic converter, egr valve, left front speed sensor, left front abs, and there is more codes but it is also throwing misfire codes 1-6 with a random. any suggestions on what could be doing this?
Old 09-02-2015, 07:30 PM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: misfire erg
If you would, post the specific codes.
Several codes can relate to the same problem or multiple problem.
Misfire can be caused by;
Weak ignition.
Low fuel pressure.
Clogged EGR ports/non functional EGR valve.
Valves out of adjustment(too tight), usually exhaust side is the side that will need it.
Burnt valves(from out of spec clearance, look above)
Low/No compression (from burnt valves, damaged rings, damagaged cylinder).
If you can post the actual codes from your car that would do wonders for online armchair diagnostics.
Old 09-05-2015, 01:54 PM
Icon4 Re: misfire erg
14-1
61-1
81-1
p0301
p0302
p0303
p0304
p0305
p0306
p0401
p1399
p0401
p0300
p0301
p0302
p0303
p0304
p0305
p0306
those are all the codes that were pulled
Old 09-05-2015, 06:02 PM
MM Gruppe B
MAD_MIKE's Avatar
Originally Posted by princesa0504
14-1
61-1
81-1
Those are the ABS codes, if these occurred after the transmission was replaced a sensor was not reconnected or possible damaged. Check the orange electrical connections for the ABS system.
p0301
p0302
p0303
p0304
p0305
p0306
p1399
All these misfire codes are most likely caused by this...
p0401
Exhaust gas recirculation, insufficient flow.
You will need to pull off your upper intake manifold and clean out the main EGR feed port.
Scotty shows, with reckless abandon, how to remove/clean out the port.
There are plenty of other videos on how to clean/remove the J30 intake.
Clean out that main EGR feed port out and you should have no more problems with EGR codes/misfire codes, as long as your valves have also been adjusted at regular intervals you should have no more engine codes.
Old 09-06-2015, 04:26 AM
okay thank you i will try that
Old 09-06-2015, 05:02 AM
yes the abs sensor codes came after the tranny was replaced
chsmurphy
Honda CR-V & Element
35
12-20-2021 12:25 PM
Jeremy Dunn
06-27-2017 07:56 AM
cg1shawn
06-08-2014 10:45 PM
majesticlatin
04-28-2011 03:17 AM
Accord5Gen
12-19-2009 09:26 AM
Quick Reply: misfire erg
