Transmission Control Unit
Old 07-29-2009, 12:18 PM
Kevs02Accord's Avatar
Default Transmission Control Unit
I have an 02 accord, auto. I am looking to change obd2 to 1. Do I have a separate TCU? If I do, will the obd1, with conversion harness plug into the TCU? If not would I need an obd1 ecu and TCU? Would a auto tranny from an F22 engine bolt up to my F23?
Old 07-30-2009, 11:22 AM
Default Re: Transmission Control Unit
Bump.
Old 08-01-2009, 08:06 AM
Bumpers.
Old 08-01-2009, 10:21 AM
rick_spiff's Avatar
You takin it racing? OBD-2 -> 1 conversions are illegal. apart from that, lookup the service manuals and see if the ecu talks to the tcu.
Old 08-01-2009, 12:29 PM
Why is the conversion illegal and how can they tell? What do you mean if the ecu talks to the tcu? They are one unit in the obd2, and 2 units in obd1, in either case wouldnt they communicate with each other? Or are you saying from the service manual I would be able to tell if the can communicate?
Old 08-01-2009, 01:43 PM
Lethal_Threat's Avatar
i know that if you do any obd 1 or 2 conversions that is not illegal in washington as long as you can pass emissions in some counties depending which one you live in. as far as tcu goes i think you might have to get an obd 1 tcu seperate from the ecu if you can find it for cheap i would experiment with that are you using a jumper harness?
Old 08-01-2009, 07:17 PM
I live in Ohio and right now we don't have any emissions testing, so I don't need to worry about that. From what I have read that is what I would need, an ECU and TCU from an automatic obd1 car. What do you mean by jumper harness, like a conversion harness? The other thing I need to know is even if I get the obd1 tcu can my f23 be controlled by it?
Old 08-01-2009, 08:37 PM
if it bolts up to the motor than i wouldnt see why it wouldnt work as long as the wiring is all right and ya i call a conversion harness a jumper harness its the same thing
Old 08-02-2009, 03:54 PM
good to know. that way if I cant figure out a way to make my f23 tranny controlled by the obd1 i can swap in an f22 which i know someone who made it work.
Old 08-03-2009, 06:14 AM
good luck keep us posted
Old 08-03-2009, 12:40 PM
Anyone happen to have the pinouts for my ecu? I have found some but I am not sure if they are for civics or not. See link: http://hondaswap.com/reference-mater...pinouts-28667/
Old 08-03-2009, 04:25 PM
YeuEmMaiMai's Avatar
uhm pre '98 accords had a ECM and a TCU All newer accords have them combined into one unit.
Old 08-03-2009, 05:02 PM
Exactly, thats why I need to figure out if an obd1 + separate obd1 tcu can control the f23 transmission. I think to do that I need to get pinouts for the ecu to make sure everything will hook up.
Old 08-06-2009, 11:37 AM
bump.
Civic--mini me
02-10-2014 04:16 PM
Joeski99Si
09-04-2008 10:18 AM
DC4 me
04-13-2007 04:04 PM
BLUE EH3
05-13-2005 08:19 PM
Quick Reply: Transmission Control Unit
