I need major help
Old 07-12-2010, 01:20 PM
dootery's Avatar
Icon3 I need major help
I have a 97 accord and i recently swapped my f22b2 SOHC non-vtec for a f22b1 SOHC non-vtec the problem is the crank sensor in the b1 is in the distributor not on the block so my mechanic re-wired it and got all the sensors to work together. The engine turns over but does not stay running every thing is working like it should, fuel, spark everything, and there is only one code in the computer which is the intake temp code. My mechanic and me are lost and out of ideas please help.
Old 07-12-2010, 02:52 PM
GhostAccord's Avatar
Default Re: I need major help
Not sure if it was a typo or not but the F22B1 is a SOHC VTEC. What ECU are you using?
• Fix the IAT sensor issue
• Test your IAC and FIT valves and make sure they are operating properly
• Check your fuel pressure @ the rail (38-46psi w/FPR vacuum hose disconnected) With the FPR hose connected is should be 30-37psi and the pressue should gradually rise when the hose is disconnected. If it doesn't, replace the FPR.
Old 07-12-2010, 05:15 PM
dootery's Avatar
Icon3 Re: I need major help
it was a typo it says f22b on the engine, I purchased the engine from canada. but i am using the stock ECU out of the 97 accord EX which that motor was a f22b2. Physically looking at the motor its the same thing except for some minor things on the block and the distributor. i will talk to my mechanic and let him know to check those things if he hasnt already. Thanks
Old 07-12-2010, 05:27 PM
F22B is the designation used by 3 JDM F series engines.
F22B - SOHC Non VTEC
F22B - SOHC VTEC
F22B - DOHC Non VTEC
The JDM F22B SOHC Non VTEC is identical to the OBD1 F22B2. (Canadian EX Accord)
Good luck
Old 07-12-2010, 07:31 PM
lpina650's Avatar
can anybody help me with this? i installed some dc headers on my 98 accord 4cyl. unfortunately i 4got to zip tie the extension for the o2 sensor and it got burnt. while driving the car bogged out on me and a check engine light turned on. in addition the "D" button on my shifter started flashing. any help guys??
Old 07-13-2010, 02:36 AM
Have the CEL and D4 codes scanned from your ECU. Replace your O2 Sensor or fix the open wires. I would assume that the wires have shorted causing an O2 CEL code to be triggered.
FYI, you should try not to thread jack in the future. Start your own thread to ask your questions. Or post in a thread that is dealing with a similar problem at least.
Old 07-13-2010, 11:41 AM
dootery's Avatar
ok my mechanic has checked all of the things you listed and they are good. The main issue with this swap has been the distributor it has an internal coil and the crank sensor is also in the distributor. The engine I took out has an external coil and the crank sensor was on the block. we got the engine to fire but it just doesnt run it will run good for a couple of seconds and then it just dies.
Old 07-13-2010, 12:56 PM
Did your mechanic relocate both of the sensors from the oil pump housing? The TDC sensor and the CKP (crank) sensor are both located in the distributor of the JDM F22B.
Old 07-13-2010, 01:44 PM
dootery's Avatar
Yes he did. the distributor housing code is TD-53U which goes to an accord f22A series non-vtec, and the prelude F22B DOHC non-vtec. the motor i purchased is F22B SOHC non-vtec which this distributor came on the motor. could this be the problem.
Old 07-13-2010, 03:48 PM
4671 Hybird's Avatar
See my attached post. Although my situation was different, it sounds like yours in reverse. Hope it helps and keep us posted.
http://www.superhonda.com/forum/f13/...ml#post4007984
Old 07-13-2010, 08:50 PM
dootery's Avatar
thanks for the link HYBRID and GHOSTACCORD thanks for the other info im going to go see him tomorrow and give him these print outs and maybe it will be helpful for him. Im going to check on some of the grounds and make sure they are all connected he might of overlooked them he has had my accord for about 6 weeks now its really aggrivating. Thanks and I will let you both know.
speed_demon018
87
08-14-2009 04:14 PM
em2slips
02-09-2009 06:04 PM
bucky4444
03-23-2006 01:00 PM
carsonau
06-15-2005 10:44 AM
Quick Reply: I need major help
