How to unlock radio with the code?
Old 11-29-2006, 10:28 AM
pickleseb's Avatar
Default How to unlock radio with the code?
I have gotten the code to unlock my radio (e.g. U1234L1234). Can anyone tell me how to unlock the radio? I mean, where and how to enter the code? thanks
pickleseb is offline
He knows where you live!
TheMuffinMan's Avatar
push the numbers
TheMuffinMan is offline
Old 11-29-2006, 10:35 AM
ex95cord's Avatar
Default Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">push the numbers</TD></TR></TABLE>
+1 and it will beep
ex95cord is offline
Old 11-29-2006, 10:43 AM
pickleseb's Avatar
Default Re: (ex95cord)
I tried pushing the button, the screen will show "E" and if I press one more time, it'll show "ER"...follow by "ERR"...so, do i need to push any button and hold so that I can make changes? what about the characters "U" and "L"? I only see number 1-6 buttons only.
Old 11-29-2006, 12:40 PM
that's not a code problem then , there's something wrong with the cd player, it'll say
CODE when you need to type that in just push the buttons after that
Old 11-29-2006, 05:51 PM
mrhonda2u's Avatar
Default Re: How to unlock radio with the code? (pickleseb)
you use first set of 4 numbers 1234, and second set of numbers 1234. call dealer and they can get your actual radio code. once you have 5 digit code. unplug negative battery cable for 1-3 minutes. reconnect cable, power up radio, put in 5 digit code, jam away.
mrhonda2u is offline
Old 11-29-2006, 05:56 PM
mrhonda2u's Avatar
your radio code is this: 52132. follow those other procedures if it says "err". your welcome
Old 11-29-2006, 08:45 PM
Honda-Master's Avatar
if you have tried 3 times to enter codes and did not work,, you need to disconnect battery cable for about 30 seconds, reconnect and reenter the code
Honda-Master is offline
Old 07-17-2007, 01:47 PM
vigorize123's Avatar
Default Re: How to unlock radio with the code? (mrhonda2u)
help i have the code and it is an 1994 acura vigor and my code is 031135 how do u enter that and i only have 1-6 on my dash?
vigorize123 is offline
Old 07-17-2007, 02:29 PM
you push
1 for 0 if I recall
Code - Button
0 - 1
1 - 2
2 - 3
3 - 4
4 - 5
5 - 6
mrpena
05-04-2017 03:07 AM
mitch48
04-08-2007 05:00 PM
esracer
06-25-2005 06:08 PM
SuB-CoNsCiOuS
04-27-2005 06:27 PM
BigBlockCRX
Audio / Security / Video
08-04-2004 10:54 AM
Quick Reply: How to unlock radio with the code?
