Help! Power steering fluid pushing out from reservoir cap
Old 02-12-2004, 03:59 PM
svarver's Avatar
Default Help! Power steering fluid pushing out from reservoir cap Fixed!
Replacing the pump did the trick, Thanks again.
My wifes 91 Honda has just started pushing power steering fluid out of the reservoir cap. The fluid is dark brown and smells burnt. Also the steering "chirrups" when making left or right hand turns. This started at the same time as the fluid leak. I have never added fluid, yet when I checked it was well above the full mark when the engine was cold. I had it in for an oil change at the local honda dealer about 4 weeks ago, this would be the only time that fluid might have been added. Perhaps they overfilled it?
I bled the pump and put all new Honda fluid in but it still chirrups when turning.
Is there a reason the system would suddenly start pushing fluid? Do i need a new pump? Why would the old fluid look so dark brown? I believe it was the original fluid, very old. Thanks for any suggestions.
Modified by svarver at 2:09 PM 2/25/2004
Old 02-12-2004, 04:19 PM
.bagged's Avatar
Default Re: Help! Power steering fluid pushing out from reservoir cap (svarver)
New power steering pump
Old 02-15-2004, 04:50 AM
svarver's Avatar
Default Re: Help! Power steering fluid pushing out from reservoir cap (bagged93accord)
Thanks
Old 02-15-2004, 12:52 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svarver &raquo;</TD></TR><TR><TD CLASS="quote">I bled the pump and put all new Honda fluid in but it still chirrups when turning.
What's the condition of the belt? Is it properly adjusted?
Old 02-19-2004, 07:17 AM
svarver's Avatar
Default Re: Help! Power steering fluid pushing out from reservoir cap (Chiovnidca)
I read your reply and went out and double checked the belt. Tension was good, belt has 40000 miles on it but looked good. No cracks or glazing. The local boneyard has a pump for $30.00 so I thought I try it .
Old 02-25-2004, 05:12 AM
svarver's Avatar
Default Re: Help! Power steering fluid pushing out from reservoir cap Fixed! (svarver)
Fixed! Replacement pump did the trick. Thanks again!
Old 02-25-2004, 09:37 AM
.bagged's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svarver &raquo;</TD></TR><TR><TD CLASS="quote">Fixed! Replacement pump did the trick. Thanks again!</TD></TR></TABLE>
Congrats nice DIY project
curtie94
02-24-2012 12:38 PM
pityocamptes
03-18-2011 02:50 PM
91_accordwagon
01-30-2011 07:48 PM
Silvteg95
08-01-2005 06:59 PM
Silvteg95
07-30-2005 08:54 PM
Quick Reply: Help! Power steering fluid pushing out from reservoir cap
