Front end shimmy/pulsation during braking
Old 08-16-2006, 07:31 PM
larbike's Avatar
Default Front end shimmy/pulsation during braking
I have a 92 accord. The front end has a noticeable shimmy when the brakes are applied. I checked the suspension and it does not seem to have play in it. The car rides fine even at highway speeds and the shimmy only happens when the brakes are applied. Is it possible that the brake rotors are warped? The disk pads seem like they have lots of lining left and the rotors are smooth (no gouges) . Anyone have any ideas or suggestions. What's a good way to check for rotor warpage?
Thanks in advance for any info.
Old 08-16-2006, 09:11 PM
hondadude's Avatar
Default Re: Front end shimmy/pulsation during braking (larbike)
Sounds like a typical case of Shake-n-Brake have the rotors resurfaced. To check for warped rotors you need special tool that costs more than a resurface.
Old 08-17-2006, 03:17 AM
iam7head's Avatar
Default Re: Front end shimmy/pulsation during braking (hondadude)
-wheel weight are gone
-rotor took a crap
-tie rod ends are busted
-upper ball joint has too much play
Old 08-17-2006, 04:04 AM
Hondaman56's Avatar
Location: Filthadelphia City of Brothers and Love, PA, USA
You have warped rotors. Very common to Hondas unfortunately. If its not too severe you can turn them, but if it is severe you'll have to have them replaced.
gohonda
05-14-2009 02:40 PM
BucCivicSi99
Suspension & Brakes
03-26-2009 11:08 AM
mr sandman
03-18-2009 03:13 AM
Mrfeee1
09-01-2004 09:54 AM
BDiddy
07-08-2002 07:45 AM
Quick Reply: Front end shimmy/pulsation during braking
