engine vibrates @ 40 and squeeking from rack and pinion?
Old 04-02-2011, 11:45 PM
75aces's Avatar
Default engine vibrates @ 40 and squeeking from rack and pinion?
I noticed that if I hold constant speed @ 40, the engine will sputter. It goes away when above or below 40. Any suggestions? The other concern I have is I have a torn dust boot. Not sure if it's the rack and pinionor tie rod. It squeeks going straight or turning. Is it a good idea to use replacement dust boot or replace? It was damaged by the lower ball joint breaking under acceleration. thanks.
Old 04-03-2011, 09:32 AM
poorman212's Avatar
Default Re: engine vibrates @ 40 and squeeking from rack and pinion?
On the 3rd gen (86-89) carb'd models a sputter at @ 40 mph is usually caused by the #7 vac line on the back lower base of the carb being burned/broken. If you have a manual trans, slowly acel in any gear, at about ~1,800 rpm's, does the car seem to stumble?
Yuta
11-14-2015 05:02 PM
dogbiscuit
Honda CR-V & Element
05-22-2014 11:09 AM
SlvrJdm
11-03-2012 09:15 PM
jeffhoe
02-29-2012 09:02 PM
FrostySol
Suspension & Brakes
02-04-2005 04:47 PM
Quick Reply: engine vibrates @ 40 and squeeking from rack and pinion?
