help!!trany gone bad, where can i buy a good one????
Old 05-13-2008, 10:04 PM
dannysolis92005's Avatar
Default help!!trany gone bad, where can i buy a good one????
my dad has a 2000 accord lx 4 door v6 v-tec. his trany is going out, when taking off the car will revs and goes slowly. then the gear kicks in and it jumps. where can i get a trany with low miles....please help....thanks!!!!
Old 05-14-2008, 01:05 AM
HAccord96's Avatar
Default Re: help!!trany gone bad, where can i buy a good one???? (dannysolis92005)
Call up the local salvage yards. They should have a good one available. Good luck.
Old 05-14-2008, 12:49 PM
Default Re: help!!trany gone bad, where can i buy a good one???? (HAccord96)
thaks but any particular places in so cal.
Old 05-14-2008, 05:23 PM
HAccord96's Avatar
http://car-part.com/
Old 05-15-2008, 01:11 PM
YeuEmMaiMai's Avatar
don't waste your time with a J/Y..........those things are glass. Either get a honda reman or get it rebuilt by someone who knows how to do hondas
Old 05-15-2008, 01:23 PM
professorman's Avatar
Default Re: help!!trany gone bad, where can i buy a good one???? (YeuEmMaiMai)
Yes. There are know transmission issues with that year group V6 Accord Automatic transmissions. Honda had to extend the warranty on them because of this.
I vote for http://www.car-part.com as well.
Old 05-18-2008, 01:06 AM
CrxSi707's Avatar
Default Re: help!!trany gone bad, where can i buy a good one???? (professorman)
Yes there was a warranty extension on the transmission to 7 years 9 months or 109k miles. Provided that the car does not hold a salvage title. I am a service advisor at a honda dealership and get these all the time. If you are out by mileage but not by much the dealer may be able to get goodwill assistance from honda, I've seen them pay for part if customer pays labor. I've seen them do percentage splits with the customer. How many miles on the car? Is the check engine light on with dtc of p0740?
Old 05-18-2008, 07:50 AM
Default Re: help!!trany gone bad, where can i buy a good one???? (CrxSi707)
how does the odo settlement factor into that? Honda agreed to extend the warranty period by 5% to compensate for speedo error..
it could go up to 114K or 114450?
Old 05-18-2008, 09:52 AM
CrxSi707's Avatar
109k miles is the adjusted amount including the Vaughn Class Action odometer discrepancy settlement, that would be the max for honda to pick up the entire tab for replacement, although if you are not too many miles past that you can petition for goodwill consideration. The transmission recall bulletin is 02-062 99-01 automatic transmission warranty extension. If going for goodwill consideration, it helps if you can provide maintenance/service records on transmission and also helps if you are the original owner.
This trans warranty extension included all 99-01 accord v6 and 4 cylinders, oddyssey and prelude automatic transmissions.
Old 05-24-2008, 06:06 PM
can i go to any honda dealer, or what would you recomend im in socal. thanks a lot.
Old 05-25-2008, 05:01 AM
m735is's Avatar
Default Re: (dannysolis92005)
Have you tried anything to see if the whole tranny is shot?
Fluid level correct? Drain and refill a couple of times with Honda ATF only? Tested any solenoids etc?
Throwing any codes?
Old 05-25-2008, 05:19 PM
mr sandman's Avatar
Default Re: (m735is)
i dont think 99 is included, think it's just 00-01 under the warranty
Jherschlip
Transmission & Drivetrain
02-24-2014 06:36 AM
toomtoomvroom
16
04-27-2011 01:49 PM
aznromeo4u
04-13-2011 09:27 PM
ITR32
10-21-2008 01:42 AM
Nikos
08-08-2002 08:58 AM
Quick Reply: help!!trany gone bad, where can i buy a good one????
