Easy and painless way to seperate the lower ball joint Write up w / pics
Old 01-21-2010, 01:56 PM
davey5300's Avatar
Default Easy and painless way to seperate the lower ball joint Write up w / pics
First of all Props to Crx 91Si and to the maker of the Honda painless ball joint removal video on Youtube.
I watched the video and the tried it out myself and it was sooo easy and painless. So much better then beating the control arm with a hammer or struggling with a 2 jaw puller.
I do it a little different from the video, but it's still the same thing. This was done on a 94 EX, but should apply to any car using the same suspension system.
Tools needed: 19mm and 17mm (x2) Wrenches, 1/2" drive wrench, Hydraulic jack, and jack stand
1: The obvious: loosen up the lug nuts for the wheel with the 19mm, then jack up the car. Make sure the E-brake is up, and the tranny is in reverse (or park if it's auto) then remove the wheel and place the jack stand underneath and lower and remove the jack. MAKE SURE THE CAR IS STURDY.
2: pull out the Cotter pin thats goes thru the Castle nut and stud of the lower ball joint, then Unbolt the nut with the 17mm. Important: When your breaking the nut lose, make sure that you get the wrench on the nut perfectly straight, or the wrench can slip and stripe the nut. It's a little tough because of the position.
3: now take the jack and position it underneath the rotor, then jack it up. It will jack up the knuckle. keep an eye on the jack stand to make sure that ur not jacking up the whole car.
4: now check out the gap between the lower control arm and the knuckle
what you want to do it is slide the 1/2" drive wrench into that gap, and get it in there as tight as you can. if you must Raise or lower the jack a tiny bit till it's in there snugged
5: Double check that the car is sturdy. Now Release all the pressure from the jack and let the knuckle drop down HARD. You should hear a nice SNAP sound, and the Wrench should fall.
6: raise the knuckle again and check to see if the joint separated
It should separates on the first try If it didn't then try again. Make sure you're using a 1/2" drive wrench, and make sure it's slipped in the gap tight, and make sure ur letting the jack drop as hard as possible. But keep doing it till it separates
7: before you lower the jack again, remove the thu bolt that connects the shock to the lower control arm. it's a 17mm bolt, and a 17mm nut. so you'll need two 17mm
Very Easy. Give it a try the next time your changing Axles, or Dropping the Tranny, or H22 Swap, or what ever you're doing.
Old 01-21-2010, 02:04 PM
djkurious's Avatar
Default Re: Easy and painless way to seperate the lower ball joint Write up w / pics
Wonderful write up! I did this last night and it worked like a champ first try.
Looks cold...
Old 01-21-2010, 02:10 PM
davey5300's Avatar
Thanks! I Just tried it out for the first time too. I've never been able to separate the joint before, and Now one try..snap! Yeah it was snowing while I was doing it, and pop won't let me use the garage anymore
Old 01-21-2010, 02:13 PM
canteengreen's Avatar
your a sav, out there in the snow like that!
Old 01-22-2010, 05:25 AM
H-T Order of Merit
TouringAccord's Avatar
nice write up
I've added it to the FAQ sticky
Old 01-22-2010, 07:34 AM
crx_91si's Avatar
good **** man!
Old 01-22-2010, 07:44 AM
redbull-1's Avatar
Very good and detailed write-up, with safety warnings. I seen the you-tube video a long time ago; but, this is more detailed.
Old 06-28-2011, 03:43 PM
cutsforth693doa's Avatar
Wow talk about makin life easy. One shot. Normally takes me like an hour to get a ball joint off. now seconds...
Old 08-29-2012, 05:33 PM
ThaHondaMan's Avatar
great write up! this is very useful.
Old 06-05-2013, 01:34 AM
MM Gruppe B
MAD_MIKE's Avatar
I use a 12mm Craftsman 3/8" drive deep socket.
Unbolt the sway bar endlink so it does not constrain the suspension, this allows you to really raise up the knuckle, then tap in the 12mm socket and release the jack.
Hammering and pickle forks are for the birds.
Thanks again Davey.
Old 06-05-2013, 02:37 AM
holmesnmanny's Avatar
I just use this
http://www.autozone.com/autozone/acc...er=555631_0_0_
Old 04-22-2020, 06:54 AM
domano 68's Avatar
Great idea!
hot hatch man
09-26-2015 11:13 AM
miguelv0723
11-11-2006 04:26 PM
uneek4dr
03-12-2006 05:39 AM
2camsaam
10-02-2003 07:30 AM
JPP
09-03-2002 07:37 AM
Quick Reply: Easy and painless way to seperate the lower ball joint Write up w / pics
