ABS warning light on all the time.
Old 09-16-2011, 02:32 PM
UK Texan's Avatar
Default ABS warning light on all the time.
96, Accord suddenly started showing the ABS warning light. It started after considerable work on the brakes. Nothing was done to the ABS unit, but I'm not sure if it was topped up. Does it take the same Dot 4 that the rest of the system uses? i.e. is there a separate fluid route to open the valves?
Any typical faults that give the warning light?
Great care was taken with the work and no recollection of brake sensor units being dislodged at any time.
Low mileage. Little or no rust. Need to get some more life out of it. Any help would be appreciated.
Old 09-16-2011, 06:54 PM
Lost Again's Avatar
Default Re: ABS warning light on all the time.
4 or 6 cyl?
Either way, get the codes. I'm going to guess one of the sensors got damaged. The codes will tell the story.
krazyk606
06-15-2009 07:32 AM
EXccord
09-14-2006 06:29 PM
FLATOUTRACING
12-11-2005 03:06 PM
Accord2k-Hybrid
10-27-2005 09:41 AM
MF-DIF
02-11-2004 05:35 PM
Quick Reply: ABS warning light on all the time.
