Rust, Rear Quarter F'n Rust!
Old 12-17-2005, 11:23 PM
Sardawg's Avatar
Default Rust, Rear Quarter F'n Rust!
I had the car in the garage overnight to melt the ice off and noticed a spot of rust starting to form on the most common place these cars normally rust, the rear quarter just behind the wheel. Yea it is only a little spot right now, but once they start rusting back there it seems to progress really quick. That little spot will look like this by next spring.
Damn Northern roads and their salt eat up a car.
Old 12-18-2005, 07:27 AM
Banned
94accordsedan's Avatar
See that little rubber piece around the inside of the wheel arch. Take it off, that thing accumulates water and tends to cause more rust.
Old 12-18-2005, 08:12 AM
YeuEmMaiMai's Avatar
Default Re: (94accordsedan)
It's dosent matter about that plastic peice really. the water accumulates on the endside corner and it rusts from the inside out. I have a 1994 LX that has rust in the rear quarter planel and I do not have the plastic lining on the fender well.
Old 12-18-2005, 10:23 AM
fw190bvi's Avatar
Default Re: (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">It's dosent matter about that plastic peice really. the water accumulates on the endside corner and it rusts from the inside out. I have a 1994 LX that has rust in the rear quarter planel and I do not have the plastic lining on the fender well.</TD></TR></TABLE>
yup......removing the plastic only helps delay the inevitable...
for me, driver side just looks like the paint/top layer of sheet metal is rusted....its only a light color, and its defniantly surface rust. on passenger side, not much, but the paint is bubbeling...and then the bubbles pop, and you can see the surface rust on there too
Old 12-18-2005, 10:28 AM
Banned
I didn't say it would stop rust... I said...
"Take it off, that thing accumulates water and tends to cause more rust."
Old 12-18-2005, 12:17 PM
P_Adams's Avatar
Default Re: Rust, Rear Quarter F'n Rust! (Sardawg)
I was told by several Body Shop managers that the problem of rust in that area was caused by several factors.
In the rear wheel well area:
Movement of the Bumper Cover over the course of time. The bumper cover is supported in the front by no more than a Pin/Slot arrangement and it more or less just floats there, rubbing the paint until it wears to bare metal.
In the Front Wheel Well area:
Boxed in section between wheel well and rear door. Poor/no drainage, water accumulates from inner wheel well body seams and can't drain. Condition made worst (and more prevalent) by new car dealers selling "Rusty Jones" rustproofing which blocked the drains all the more
P
Razr2
23
04-04-2009 06:47 PM
harveyy
10-18-2006 12:54 PM
prelittlelude
02-21-2005 11:43 AM
CooBlueDAB
54
12-28-2004 03:29 PM
Tommy_Gunns
10-11-2004 06:27 PM
Quick Reply: Rust, Rear Quarter F'n Rust!
