Car sputtering/rough idling when first started
Old 05-07-2011, 10:02 PM
nicolaselias's Avatar
Default Car sputtering/rough idling when first started
Hi everyone, for the last few weeks this has been happening for the first 10 or 20 seconds after starting the car, particularly on cold starts..
My mechanic apparently found some oil leaked onto the spark plugs, so he changed both the upper and lower seals. The oil possibly killed my distributor as well so we installed a new one..
My ignition, fuel and air systems are in top condition so this is something of a puzzle to me...
Why would I have this misfiring and sputtering only when I just start up..
The only thing that seems unusual on the engine to me is that the pcv valve is pretty loose.. I don't think its enough to cause a vaccuum leak, but it still feels looser than I remember it being..
Other than that, everything is in good condition..
Any ideas?
I was thinking IACV as well, but as I said the problem is only for 10 or 20 seconds when I first start the car..
Old 05-07-2011, 10:19 PM
BlUAc's Avatar
Default Re: Car sputtering/rough idling when first started
you said uur fuel is in top condition, so you replaced the fuel filter. that was the first thing that popped in my head.
Old 05-07-2011, 11:37 PM
yep, changed the fuel filter same time I changed the spark plug seals with a purolator filter...
That said, I always figured a clogged fuel filter will show up higher up in the revs than at idle..
Old 05-08-2011, 05:00 AM
poorman212's Avatar
Do a leak down test, a small HG leak will allow coolant into the cyl when cold. The "sputtering/rough idle" would be the coolant being burned off.....
Old 05-08-2011, 06:36 AM
hmm, definitely something that I havent considered... I will get that checked out..
I never really think about HG's having minor failures, normally you think about something BIG when it happens..
Thanks
Old 05-08-2011, 12:23 PM
andzac's Avatar
vaccum leak
Old 05-08-2011, 12:56 PM
I was thinking vaccum but where should I check for it?
Assuming that it isnt the pcv, then what can it be?
Old 05-08-2011, 01:07 PM
CDelgado220's Avatar
Did they also change out the valve cover gasket? Have you cleaned out the egr ports?
Possibly one of the tubes was knocked or dislodged when they replaced the gaskets.
dperfect
02-22-2014 10:05 PM
RDAYA0
14
04-17-2008 03:42 PM
Maireeka
11-26-2007 04:55 AM
rscawley
08-20-2003 02:54 PM
Quick Reply: Car sputtering/rough idling when first started
