Brake lamp warning light
Old 03-30-2014, 06:19 PM
  #26
Hazelschild's Avatar
Default Re: Brake lamp warning light
Originally Posted by 88accord
Does anyone know how I can get this light to go off ? I have checked all the brake light bulbs and they are all good. When I start the car it is off, but once I press the brake pedal it comes back on.
Old 03-30-2014, 06:30 PM
  #27
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
dont know why you bumped this, if the brake light warning is on in the icon in the middle of the gauges, and all brake light bulbs are working, including the third brake light, then you need to replace the module attached to the tail light, also if any of the brake light bulbs have been replaced with LED bulbs, the light will stay on
Old 04-19-2016, 08:29 PM
  #28
Georgewlee24's Avatar
When the "Brake Lights" warning on my dashboard turned on, I checked my lights and found out that a few of them including the center brake light ( I have a 1999 DX Honda Accord) were not working so I went to buy a few bulbs and replaced the center brake light, the rear tail and brake lights (all on the left side) including my turn signal lights. The warning light turned off but the moment I stepped on the brakes, it began to turn on again. I was very frustrated. Because it was day time, I could not see the lights very clearly as the sun was very bright. I waited till the early evening hours and checked the lights again. It was then I noticed that when the brake lights were on, the left side was not as bright as the right side. I then opened and accessed the left brake lights console and I found out that if you try to reach further down to the left, there was another bulb down there. It was a little harder to reach but I manage to unscrew it and found a burnt light bulb. I had the bulb replaced and voila, I got the "brake lights' problem fixed and the warning light did not turn back on even after repeatedly stepping on the brakes. I hope this will help as I noticed a lot of people have the same problem.
Old 03-24-2018, 09:29 PM
  #29
92cb74lyfe's Avatar
I have a 92 cb7 accord 4 door as well. the brake lamp light stays on all the time. the brake levels are good the fuses are good. and so are the bulbs all led,and the connections as well. But the e-brake light used to come on in a turn do to a faultly sensor. every once and awhile my brake lamp light wont come on whenever i hit my brake.. but then it does. Im thinking its a sensor in the brake petal. or a wire touching somewhere. I have done alot of work to my car. and have a manual for 90-03 accords. hmu with any questions maybe i can help!
vic_houston
02-17-2023 03:29 PM
nicolaselias
12-22-2011 03:58 PM
tennbidder
Acura TL, RL & ZDX
06-09-2007 06:27 PM
'Accord Ex'
01-23-2007 07:18 PM
92siracer
08-27-2005 10:11 AM
Quick Reply: Brake lamp warning light
