Bolt missing from oil pan? WTF?
Old 07-14-2007, 12:49 PM
paawk2000's Avatar
Default Bolt missing from oil pan? WTF?
So I jack up the good ole accord to do an oil change.
I find oil all over the bottom of the engine, oil pan. I'm thinking hell no, not an oil leak. I never saw any oil on my driveway.
Anyway I drain the oil, filter, then I notice a freaking bolt is missing from the oil pan. Not sure how a bolt simply drops out of my pan, by itself. But I'm fairly sure its the cause of the leak.
What kind of bolt do I need to replace it? Can I just screw it back in and go on my merry way?
Here;'s a pic
I'm guessing oil only leaked out when the engine was really hot. Because I've never seen any leaking oil. Or maybe it's just a very slow leak. Regardless I'm hoping I can just screw a new bolt in there?
Old 07-14-2007, 01:46 PM
BLKFLSH's Avatar
Default Re: Bolt missing from oil pan? WTF? (paawk2000)
Those bolts do not require much torque, so it may have just loosened up on it's own. I would check to see how tight/loose the rest of them are. You could loose more of them down the road.
Old 07-14-2007, 02:00 PM
fastazzf22's Avatar
Default Re: Bolt missing from oil pan? WTF? (BLKFLSH)
Youll need to get another bolt . Take one out . Take it to your local hareware store and match the bolt up . Did you see that the area of oil on the pan came from the location of the missing bolt ??
Old 07-14-2007, 07:22 PM
Bruce Banner's Avatar
Default Re: Bolt missing from oil pan? WTF? (fastazzf22)
OSH or home depot will have a nut for that.
Old 07-15-2007, 03:56 AM
SHAME ON YOU REBECCA!
kidcool1977's Avatar
Default Re: Bolt missing from oil pan? WTF? (Bruce Banner)
i were you i'd go to the dealer to get it and call it a day, what's the most you'd pay for that 10 mm bolt 2 bucks Tops.
Old 07-15-2007, 06:03 AM
Jstall7543's Avatar
Don't overtighten it or you will crush the pan gasket!
Old 07-15-2007, 05:50 PM
JDM_DC4_Fanatic's Avatar
Default Re: Bolt missing from oil pan? WTF? (Jstall7543)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jstall7543 &raquo;</TD></TR><TR><TD CLASS="quote"> Don't overtighten it or you will crush the pan gasket!</TD></TR></TABLE>
x2
I would change the pan gasket anyway. the gasket could have cracks in it from being loose.
Old 07-16-2007, 07:54 PM
professorman's Avatar
Default Re: Bolt missing from oil pan? WTF? (JDM_DC4_Fanatic)
Put some locktight on it when you re-install the new bolt. That will keep it from randomly falling out.
jdm27ef
03-24-2010 08:35 AM
kaychi
07-09-2008 12:10 PM
ombl4
05-10-2007 01:42 PM
MechEng
10-21-2005 12:14 PM
JDM88EF9
12
09-19-2002 07:45 AM
Quick Reply: Bolt missing from oil pan? WTF?
