Alternator Install?
Re: Alternator Install? (londonsupra)
Pretty straight foward job. remove the P/S pump 2 bolts, lay it off to the drivers side, leave the hoses hooked up. Disconnect the neg batt terminal. unplug the ALT, and remove the big batt lead on the ALT. Then a 14 mm bolt on the top of the ALT and a 12mm nut on the bottom. slip out the lower tensioning bolt; wiggle the ALT and pull up. Taaa DAAAA
Kajun
05-27-2019 09:36 AM
