are all f22 distributors the same
Old 07-14-2008, 04:53 PM
ashb82's Avatar
Default are all f22 distributors the same
i am putting a f22b1 vtec in my car will a f22 non vtec distributor work. The vtec distributor wiring is only 5 wire and a 4 wire crank sensor. where my old motor did not have the crank sensor
Old 07-14-2008, 05:12 PM
gianinline's Avatar
there's internal coil and external coil... you need to find out which one is yours.
In my case, f22b1 (obd2).... the coil was internal. I believe that f22b2's are external... but... they're not all the same.
Old 07-14-2008, 05:14 PM
ashb82's Avatar
Default Re: (gianinline)
i have the internal coil wirh only 5 wires coming out of it
Old 07-14-2008, 06:01 PM
gianinline's Avatar
What year is your car and what year is the new motor you got?!
Old 07-14-2008, 06:20 PM
ashb82's Avatar
its a 95 civic and the engine is a 97 accord. i have a h22 that i am building so i just needed a engine to get the car running so i could drive it. when i did the h22 swap i pulled the guts out and put in my civic guts. but i cant seem to do this on the f22. I am going to run a p28 with f22 vtec base map. the f22 engine has a crank sensor that my guess that is why only the 5 wire dizzy. could i wire that crank sensor up on my obd 1 ecu
downNoutCD5
02-22-2013 03:17 PM
Jammer30
05-24-2010 04:57 PM
jbonehead85
12-08-2004 04:01 PM
Excelerate
07-07-2003 09:32 PM
Quick Reply: are all f22 distributors the same
