Accord 1996 : PCV Hose
Old 04-07-2014, 05:24 PM
curvenut's Avatar
Default Accord 1996 : PCV Hose
Hi,
I just broke my PCV Hose when replacing my PCV valve.
I just check online and just the hose cost 36$$$
http://www.hondapartsunlimited.com/h...acuum-7-3x3000
Where can I find and what king of hose can be used a cheaper solution to replace the PCV hose ??
Thanks
Old 04-07-2014, 06:22 PM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: Accord 1996 : PCV Hose
Originally Posted by curvenut
Hi,
bulk-hose-vacuum-7.3x3000
Thanks
Did you look at the description?
7.3mm hose x 3000mm. 'bulk'. That's 3Meters of 7.3 hose at Honda prices.
Go to your local parts shop and look for 7.3mm vacuum or fuel hose, if no metric sizes look for 9/32", you will need about a foot.
Should be a dollar out the door.
Old 04-07-2014, 06:25 PM
curvenut's Avatar
I just notice "bulk" !!
I ll check at the part store !
Thanks Mike
Old 04-07-2014, 08:14 PM
accordturb96's Avatar
I used some high temp hose black rubber hose. The heat of the oil tends to break down and collapse the weaker tube material
Old 04-07-2014, 10:40 PM
holmesnmanny's Avatar
You can't use regular vacuum hose for the pcv hose as there is high heat and a bit of oil running through it.
Old 04-08-2014, 02:23 AM
Ok, not really oil as much as fuel the more I think of it.
Old 04-11-2014, 06:45 AM
curvenut's Avatar
Ok, I found some windshield cleaner tube that is made of rubber . It had the same diameter of 9/32 or 7.3 mm.
I installed it , well I will see it it handle the heat
Is that good ? I don't really known about the temperature it can handle.
Old 04-11-2014, 09:50 AM
jvr
jvr's Avatar
I thought it was mostly oil in the pcv valve/hose? When I replaced mine recently there was definitely oil clogging the valve and leaking out of the grommet (the grommet was cracked)
Old 04-11-2014, 10:06 AM
curvenut's Avatar
It is motsly oil as far as I can see and smell when I changed mine.
Did you changed you hose too ? If yes what kind of hose did you use ?
Old 04-11-2014, 10:13 AM
MM Gruppe B
MAD_MIKE's Avatar
Wiper hose will probably not last long, but it is better than nothing in the interim.
Reinforced vacuum hose that is fuel resistant or fuel hose would be better.
Oil vapor and blowby are what will be in the crankcase and recirculated via the PCV system.
Old 04-11-2014, 10:19 AM
jvr
jvr's Avatar
Right, so it's just oil and various gases (not gasoline) that go through the pcv system? Just curious why Holmes said fuel was in there instead of oil
Old 04-11-2014, 10:22 AM
MM Gruppe B
MAD_MIKE's Avatar
Fuel vapor, as in blowby, will travel in the line. Anything that is not fuel rated will deteriorate from gasoline/gasoline vapors.
Old 04-11-2014, 11:55 AM
jvr
jvr's Avatar
Gotcha. I thought blowby just meant exhaust gases that sneak through the piston rings Thanks for the clarification.
Old 04-11-2014, 02:49 PM
MM Gruppe B
MAD_MIKE's Avatar
Blowby are the gasses that get blown by the rings, and valve seals.
Azaria
07-26-2016 09:30 PM
HndaOwner
03-08-2016 04:14 PM
Cheyfamily
10-17-2015 05:12 AM
hose
Honda Motorcycles
06-19-2006 08:28 AM
Quick Reply: Accord 1996 : PCV Hose
