abs brake system malfunction
I changed the front brake pads two weeks ago, using Honda parts. I bled the entire system. Two weeks later the ABS light comes on. When I start the car it comes on as usual, turns off, and after 30 to 45 seconds comes back on. All fuses, etc. are fine. Do the brakes need bleeding? Do I have a bad wheel sensor?
The malfunction happened after the car sat overnight, it did not come on while driving, it just came on first thing in the morning after starting up. Thanks for the help. 1996 EX Accord, 4 cylinder, automatic. The ABS resevoir is full, no leaks. Brake pedal is firm, good braking action.
[Modified by davglt, 12:44 AM 2/11/2003]
[Modified by davglt, 1:09 AM 2/11/2003]
Re: abs brake system malfunction (davglt)
When you had the wheels off did you inspect the wheel sensors? If the wheel sensors are caked with dirt or grease, they will not send a signal which will trigger the ABS light to come on and the system will not function.
Re: abs brake system malfunction (Stew Pidasso)
wheel sensors are clean, you start the car up, the light comes on, it goes off normally and then comes on again 30 to 45 seconds later and stays on. Sounds like the pump or it needs bleeding I guess. This all happens while the car is stationary.
Thanks
Thanks
Read this thread. It may apply to your situation.
https://honda-tech.com/zerothread?id=241713
Results: bled the ABS unit, refilled, bled it again, and refilled. the unit was always full but now it does work! Thanks for the help and the responses. this is a great board!
SpeedFreek34
07-22-2007 05:43 PM
