98 Honda Accord not starting HELP!
98 honda accord ex 4 cylinder not starting
Alright i have seen thread after thread about this problem.
The car is turning over but not starting.
Fuses are all good.
The car is getting spark and it has fuel pressure.
I have changed the ignition switch.
I can here the main relay click when turning the key on.
The immobilizer is reading the key. Green key light comes on the goes off like i read it should do.
The only thing i have noticed is where the key goes is has some play. I noticed that key has some play between the off and 1. so when the door is open the car will be beeping at me and then when i move it just a hair up the beeping stops.
Could my problem be where the key goes in is wore out?
Im thinking i need the full assembly bellow, what do yall think?
Of course if this is my issue how can i program the keys to the car?
http://www.oreillyauto.com/site/c/se...21s%21assembly
Fuses are all good.
Re: 98 Honda Accord not starting HELP!
Hi I have a 97 accord with similar no start trouble,if I disconnect the battery then reconnect it the car will start once, maybe twice, then wont start again. It has fire, new main relay, can hear fuel pump, checked all grounds, previous owner replaced control module, plugs, wires , and battery. What could it be?
My 96 Honda Accord will not start. I have spark to plugs. I replaced the main relay and fuel pump. The ECM is not activating the main relay to activate the fuel pump. Any ideas?
there should be voltage at the black/yellow wire at the dizzy when cranking or key on. if no voltage replace lock cylinder may not be making contact.
are you getting full 12 volts at the black/yellow? bad switch equal resistance. resistance higher impedance. harder to develop full 12 volts of spark my car never started when my old battery was under 12 volts once i tried to crank it it dropped to 10 volts and never started. and just because you see spark doesn't mean its enough to actually light the fuel and air mixture. you need a spark tester that lets gap the spark so you can push the maximum output of the coil. this also could be done with a screw driver lightly pushed into the spark plug wire and set the screw driver at a distance from something metal so you can see spark distance and color. check compression as well. you say there is fuel pressure, but are the injectors opening when you crank it for a while and take out the spark plug do they smell like fuel??? also check timing
Last edited by NerfGunner420; 05-04-2014 at 12:13 PM. Reason: what is the fuel pressure?
The car was running fine one day and the next it didn't. I sprayed starter fluid in the intake and the engine sputtered. I have had a battery charger on the battery and it turns over at a good rate. It checked out the new main relay and it is good. When I turn the key to the second position the fuel pump does not turn on. I have tested the f/p and it work when there is power to it. I am wondering if the ecm is bad.
yes its the same .. sounds like the ecu is bad going by your test results
im guessing you used this site ...
http://techauto.tripod.com/
Elvis1977
10-29-2018 10:08 AM
t-tom
11-05-2015 09:02 AM
FullClippers
07-01-2010 01:04 PM
