98 Accord - Window Switch from Hell
Girlfriend's driver's side window doesn't go up or down, and the switch doesn't activate any of the other windows. The other windows work fine if you use their switches. I had a friend supply voltage directly to her window motor, and it went up/down - no problem. I figured it was a bad window switch on the driver's side door. Replaced that - didn't fix the issue. I've been trying to find diagrams of the actual connectors for the switch, so I can make sure voltage is actually reaching the switch, or if so, if voltage is leaving the switch. I checked the fuse and that wasn't blown. I'm wondering if it's a lack of adequate power supply on one of the wires going to switch. I am not sure where to go from this point, and have had no luck finding the actual diagrams for the connectors. Thanks for any info you guys can give. It's becoming more of a nuisance than I originally anticipated!
Re: 98 Accord - Window Switch from Hell
I hate electrical..........
A1 - hot at all times
A2 - hot with KO
A12 / A19 / B1 - continuity to ground
Drivers window down - Jump these
A11 to A12
A10 to A1
A2 - hot with KO
A11 to A12
A10 to A1
Thank you for that diagram. I have gotten the master switch to work with the driver's front and rear windows, but it does not operate either of the passenger side windows. All windows work with their respective switches, though. Do you have the same diagram for the passenger side multiplex control unit? That's what I'm assuming is wrong now. I am narrowing it down! Almost there!
I'd pull up my wiring diagram for the power windows but they're in a box somewhere. If you can pull up the page(s) for the power windows I can trace the wiring for you to check for continuity.
Sorry for the delay....I don't get on here that much.
See if this thread helps: http://www.hondaaccordforum.com/foru...s-48037/page2/
MtbikingKing
05-05-2006 09:27 PM
