Weird Idle when cold!?!
Old 11-15-2006, 09:06 PM
Integra_drk's Avatar
Default Weird Idle when cold!?!
Alright, just dropped a new motor in the accord and upon startup it revs up and down. up to like 3k and then back down. After about 5 minutes of this crap it idles normally. i was thinking IACV so i replaced it and it still does it. Any other ideas? Checked for vacuum leaks and found none. TIA
Modified by Integra_drk at 7:37 AM 11/16/2006
Old 11-15-2006, 09:59 PM
ex95cord's Avatar
your sure all the vacuum lines are routed right? I had some messed up and my idle would bounce too, not as wide a range as yours but.
Old 11-16-2006, 05:36 AM
Default Re: (ex95cord)
yea im pretty sure everything is hooked up right, but apparently something isnt. It did that with the old motor in there too. anybody else?
Old 11-16-2006, 10:25 AM
hondadude's Avatar
Default Re: Weird Idle when cold!?! (Integra_drk)
1st Burp the air out of the coolant system, next would be to adjust the cold start fast idle valve
Old 11-17-2006, 07:31 AM
Default Re: Weird Idle when cold!?! (hondadude)
and where is that located? how do you adjust it?
Old 11-17-2006, 11:36 AM
hondadude's Avatar
#14 in the attached link
http://www.hondaautomotivepart...+BODY
you sould remove the cap that has the 2 philips head screws; then turn in the nylon 'split' screw in a couple turns.
TearSDMF89dx
01-03-2012 04:31 AM
accord9t3
11-20-2004 02:17 PM
94dxt
08-14-2003 09:03 PM
91SE
02-18-2003 04:35 PM
Quick Reply: Weird Idle when cold!?!
